indev_button_proc
(line 661 of lv_core/lv_indev.c
) can badly fail if there is no point(s) array set.
ESP32+microPython+LVGL6.1
What do you experience?
If I forget (silly me ) to set the points array for a LV_INDEV_TYPE_BUTTON
input device driver, then invariably the program fails with a hard-reset of the microcontroller.
Looking at the C code, if one does not set the points array using lv_indev_set_button_points
, then things go badly wrong. Basically lines 663-4 of lv_core/lv_indev.c
will try to access inexistant data by dereferencing a NULL
pointer (as far as I can tell when an input device is registered, then its btn_points
field is set to NULL
However, looking in the same file at the code to handle groups then one sees (lines 376-80 and 531-35) that the absence of a group is handled gracefully; by a return if NULL
What do you expect?
A graceful failure. Basically a test wether btn_points==NULL
. Copying what is found to handle the case where group==NULL
(see lines 376-7, 531-2 of lv_indev.c
), one could imagine having the following between lines 662 and 663:
lv_point_t * pts = i->btn_points;
if (pts==NULL) return;
