while loop executes infinitely. (vdb->flushing is 1)
static void lv_refr_area_part(const lv_area_t * area_p)
lv_disp_buf_t * vdb = lv_disp_get_buf(disp_refr);
/*In non double buffered mode, before rendering the next part wait until the previous image is
* flushed*/
if(lv_disp_is_double_buf(disp_refr) == false) {
while(vdb->flushing)
my lv_conf.h
* @file lv_conf.h
* COPY THIS FILE AS `lv_conf.h` NEXT TO the `lvgl` FOLDER
#ifndef LV_CONF_H
#define LV_CONF_H
/* clang-format off */
#include <stdint.h>
Graphical settings
/* Maximal horizontal and vertical resolution to support by the library.*/
#define LV_HOR_RES_MAX (480)
#define LV_VER_RES_MAX (272)
/* Color depth:
* - 1: 1 byte per pixel
* - 8: RGB233
* - 16: RGB565
* - 32: ARGB8888
#define LV_COLOR_DEPTH 16
/* Swap the 2 bytes of RGB565 color.
* Useful if the display has a 8 bit interface (e.g. SPI)*/
#define LV_COLOR_16_SWAP 0
/* 1: Enable screen transparency.
* Useful for OSD or other overlapping GUIs.
* Requires `LV_COLOR_DEPTH = 32` colors and the screen's style should be modified: `style.body.opa = ...`*/
#define LV_COLOR_SCREEN_TRANSP 0
/*Images pixels with this color will not be drawn (with chroma keying)*/
#define LV_COLOR_TRANSP LV_COLOR_LIME /*LV_COLOR_LIME: pure green*/
/* Enable anti-aliasing (lines, and radiuses will be smoothed) */
#define LV_ANTIALIAS 1
/* Default display refresh period.
* Can be changed in the display driver (`lv_disp_drv_t`).*/
#define LV_DISP_DEF_REFR_PERIOD 30 /*[ms]*/
/* Dot Per Inch: used to initialize default sizes.
* E.g. a button with width = LV_DPI / 2 -> half inch wide
* (Not so important, you can adjust it to modify default sizes and spaces)*/
#define LV_DPI 100 /*[px]*/
/* Type of coordinates. Should be `int16_t` (or `int32_t` for extreme cases) */
typedef int16_t lv_coord_t;
Memory manager settings
/* LittelvGL's internal memory manager's settings.
* The graphical objects and other related data are stored here. */
/* 1: use custom malloc/free, 0: use the built-in `lv_mem_alloc` and `lv_mem_free` */
#define LV_MEM_CUSTOM 1
#if LV_MEM_CUSTOM == 0
/* Size of the memory used by `lv_mem_alloc` in bytes (>= 2kB)*/
# define LV_MEM_SIZE (32U * 1024U)
/* Complier prefix for a big array declaration */
# define LV_MEM_ATTR
/* Set an address for the memory pool instead of allocating it as an array.
* Can be in external SRAM too. */
# define LV_MEM_ADR 0
/* Automatically defrag. on free. Defrag. means joining the adjacent free cells. */
# define LV_MEM_AUTO_DEFRAG 1
#else /*LV_MEM_CUSTOM*/
# define LV_MEM_CUSTOM_INCLUDE "FreeRTOS.h" //<stdlib.h> /*Header for the dynamic memory function*/
# define LV_MEM_CUSTOM_ALLOC pvPortMalloc //malloc /*Wrapper to malloc*/
# define LV_MEM_CUSTOM_FREE vPortFree //free /*Wrapper to free*/
#endif /*LV_MEM_CUSTOM*/
/* Garbage Collector settings
* Used if lvgl is binded to higher level language and the memory is managed by that language */
#define LV_ENABLE_GC 0
#if LV_ENABLE_GC != 0
# define LV_GC_INCLUDE "gc.h" /*Include Garbage Collector related things*/
# define LV_MEM_CUSTOM_REALLOC your_realloc /*Wrapper to realloc*/
# define LV_MEM_CUSTOM_GET_SIZE your_mem_get_size /*Wrapper to lv_mem_get_size*/
#endif /* LV_ENABLE_GC */
Input device settings
/* Input device default settings.
* Can be changed in the Input device driver (`lv_indev_drv_t`)*/
/* Input device read period in milliseconds */
#define LV_INDEV_DEF_READ_PERIOD 30
/* Drag threshold in pixels */
#define LV_INDEV_DEF_DRAG_LIMIT 10
/* Drag throw slow-down in [%]. Greater value -> faster slow-down */
#define LV_INDEV_DEF_DRAG_THROW 20
/* Long press time in milliseconds.
* Time to send `LV_EVENT_LONG_PRESSSED`) */
#define LV_INDEV_DEF_LONG_PRESS_TIME 400
/* Repeated trigger period in long press [ms]
* Time between `LV_EVENT_LONG_PRESSED_REPEAT */
#define LV_INDEV_DEF_LONG_PRESS_REP_TIME 100
* Feature usage
/*1: Enable the Animations */
#define LV_USE_ANIMATION 1
#if LV_USE_ANIMATION
/*Declare the type of the user data of animations (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_anim_user_data_t;
/* 1: Enable shadow drawing*/
#define LV_USE_SHADOW 1
/* 1: Enable object groups (for keyboard/encoder navigation) */
#define LV_USE_GROUP 1
#if LV_USE_GROUP
typedef void * lv_group_user_data_t;
#endif /*LV_USE_GROUP*/
/* 1: Enable GPU interface*/
#define LV_USE_GPU 1
/* 1: Enable file system (might be required for images */
#define LV_USE_FILESYSTEM 1
#if LV_USE_FILESYSTEM
/*Declare the type of the user data of file system drivers (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_fs_drv_user_data_t;
/*1: Add a `user_data` to drivers and objects*/
#define LV_USE_USER_DATA 0
* Image decoder and cache
/* 1: Enable indexed (palette) images */
#define LV_IMG_CF_INDEXED 1
/* 1: Enable alpha indexed images */
#define LV_IMG_CF_ALPHA 1
/* Default image cache size. Image caching keeps the images opened.
* If only the built-in image formats are used there is no real advantage of caching.
* (I.e. no new image decoder is added)
* With complex image decoders (e.g. PNG or JPG) caching can save the continuous open/decode of images.
* However the opened images might consume additional RAM.
* LV_IMG_CACHE_DEF_SIZE must be >= 1 */
#define LV_IMG_CACHE_DEF_SIZE 1
/*Declare the type of the user data of image decoder (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_img_decoder_user_data_t;
* Compiler settings
/* Define a custom attribute to `lv_tick_inc` function */
#define LV_ATTRIBUTE_TICK_INC
/* Define a custom attribute to `lv_task_handler` function */
#define LV_ATTRIBUTE_TASK_HANDLER
/* With size optimization (-Os) the compiler might not align data to
* 4 or 8 byte boundary. This alignment will be explicitly applied where needed.
* E.g. __attribute__((aligned(4))) */
#define LV_ATTRIBUTE_MEM_ALIGN
/* Attribute to mark large constant arrays for example
* font's bitmaps */
* HAL settings
/* 1: use a custom tick source.
* It removes the need to manually update the tick with `lv_tick_inc`) */
#define LV_TICK_CUSTOM 0
#if LV_TICK_CUSTOM == 1
#define LV_TICK_CUSTOM_INCLUDE "something.h" /*Header for the sys time function*/
#define LV_TICK_CUSTOM_SYS_TIME_EXPR (millis()) /*Expression evaluating to current systime in ms*/
#endif /*LV_TICK_CUSTOM*/
typedef void * lv_disp_drv_user_data_t; /*Type of user data in the display driver*/
typedef void * lv_indev_drv_user_data_t; /*Type of user data in the input device driver*/
* Log settings
/*1: Enable the log module*/
#define LV_USE_LOG 1
#if LV_USE_LOG
/* How important log should be added:
* LV_LOG_LEVEL_TRACE A lot of logs to give detailed information
* LV_LOG_LEVEL_INFO Log important events
* LV_LOG_LEVEL_WARN Log if something unwanted happened but didn't cause a problem
* LV_LOG_LEVEL_ERROR Only critical issue, when the system may fail
* LV_LOG_LEVEL_NONE Do not log anything
# define LV_LOG_LEVEL LV_LOG_LEVEL_TRACE
/* 1: Print the log with 'printf';
* 0: user need to register a callback with `lv_log_register_print`*/
# define LV_LOG_PRINTF 1 //0
#endif /*LV_USE_LOG*/
* THEME USAGE
#define LV_THEME_LIVE_UPDATE 0 /*1: Allow theme switching at run time. Uses 8..10 kB of RAM*/
#define LV_USE_THEME_TEMPL 0 /*Just for test*/
#define LV_USE_THEME_DEFAULT 0 /*Built mainly from the built-in styles. Consumes very few RAM*/
#define LV_USE_THEME_ALIEN 0 /*Dark futuristic theme*/
#define LV_USE_THEME_NIGHT 0 /*Dark elegant theme*/
#define LV_USE_THEME_MONO 0 /*Mono color theme for monochrome displays*/
#define LV_USE_THEME_MATERIAL 0 /*Flat theme with bold colors and light shadows*/
#define LV_USE_THEME_ZEN 0 /*Peaceful, mainly light theme */
#define LV_USE_THEME_NEMO 0 /*Water-like theme based on the movie "Finding Nemo"*/
* FONT USAGE
/* The built-in fonts contains the ASCII range and some Symbols with 4 bit-per-pixel.
* The symbols are available via `LV_SYMBOL_...` defines
* More info about fonts: https://docs.littlevgl.com/#Fonts
* To create a new font go to: https://littlevgl.com/ttf-font-to-c-array
/* Robot fonts with bpp = 4
* https://fonts.google.com/specimen/Roboto */
#define LV_FONT_ROBOTO_12 0
#define LV_FONT_ROBOTO_16 1
#define LV_FONT_ROBOTO_22 0
#define LV_FONT_ROBOTO_28 0
/*Pixel perfect monospace font
* http://pelulamu.net/unscii/ */
#define LV_FONT_UNSCII_8 0
/* Optionally declare your custom fonts here.
* You can use these fonts as default font too
* and they will be available globally. E.g.
* #define LV_FONT_CUSTOM_DECLARE LV_FONT_DECLARE(my_font_1) \
* LV_FONT_DECLARE(my_font_2)
/*Always set a default font from the built-in fonts*/
#define LV_FONT_DEFAULT &lv_font_roboto_16
/* Enable it if you have fonts with a lot of characters.
* The limit depends on the font size, font face and bpp
* but with > 10,000 characters if you see issues probably you need to enable it.*/
#define LV_FONT_FMT_TXT_LARGE 0
/*Declare the type of the user data of fonts (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_font_user_data_t;
* Text settings
/* Select a character encoding for strings.
* - LV_TXT_ENC_UTF8
* - LV_TXT_ENC_ASCII
#define LV_TXT_BREAK_CHARS " ,.;:-_"
* LV_OBJ SETTINGS
/*Declare the type of the user data of object (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_obj_user_data_t;
/*1: enable `lv_obj_realaign()` based on `lv_obj_align()` parameters*/
#define LV_USE_OBJ_REALIGN 1
/* Enable to make the object clickable on a larger area.
* LV_EXT_CLICK_AREA_OFF or 0: Disable this feature
* LV_EXT_CLICK_AREA_TINY: The extra area can be adjusted horizontally and vertically (0..255 px)
* LV_EXT_CLICK_AREA_FULL: The extra area can be adjusted in all 4 directions (-32k..+32k px)
#define LV_USE_EXT_CLICK_AREA LV_EXT_CLICK_AREA_OFF
* LV OBJ X USAGE
* Documentation of the object types: https://docs.littlevgl.com/#Object-types
/*Arc (dependencies: -)*/
#define LV_USE_ARC 1
/*Bar (dependencies: -)*/
#define LV_USE_BAR 1
/*Button (dependencies: lv_cont*/
#define LV_USE_BTN 1
#if LV_USE_BTN != 0
/*Enable button-state animations - draw a circle on click (dependencies: LV_USE_ANIMATION)*/
# define LV_BTN_INK_EFFECT 0
/*Button matrix (dependencies: -)*/
#define LV_USE_BTNM 1
/*Calendar (dependencies: -)*/
#define LV_USE_CALENDAR 1
/*Canvas (dependencies: lv_img)*/
#define LV_USE_CANVAS 1
/*Check box (dependencies: lv_btn, lv_label)*/
#define LV_USE_CB 1
/*Chart (dependencies: -)*/
#define LV_USE_CHART 1
#if LV_USE_CHART
# define LV_CHART_AXIS_TICK_LABEL_MAX_LEN 20
/*Container (dependencies: -*/
#define LV_USE_CONT 1
/*Drop down list (dependencies: lv_page, lv_label, lv_symbol_def.h)*/
#define LV_USE_DDLIST 1
#if LV_USE_DDLIST != 0
/*Open and close default animation time [ms] (0: no animation)*/
# define LV_DDLIST_DEF_ANIM_TIME 200
/*Gauge (dependencies:lv_bar, lv_lmeter)*/
#define LV_USE_GAUGE 1
/*Image (dependencies: lv_label*/
#define LV_USE_IMG 1
/*Image Button (dependencies: lv_btn*/
#define LV_USE_IMGBTN 1
#if LV_USE_IMGBTN
/*1: The imgbtn requires left, mid and right parts and the width can be set freely*/
# define LV_IMGBTN_TILED 0
/*Keyboard (dependencies: lv_btnm)*/
#define LV_USE_KB 1
/*Label (dependencies: -*/
#define LV_USE_LABEL 1
#if LV_USE_LABEL != 0
/*Hor, or ver. scroll speed [px/sec] in 'LV_LABEL_LONG_ROLL/ROLL_CIRC' mode*/
# define LV_LABEL_DEF_SCROLL_SPEED 25
/* Waiting period at beginning/end of animation cycle */
# define LV_LABEL_WAIT_CHAR_COUNT 3
/*Enable selecting text of the label */
# define LV_LABEL_TEXT_SEL 0
/*Store extra some info in labels (12 bytes) to speed up drawing of very long texts*/
# define LV_LABEL_LONG_TXT_HINT 0
/*LED (dependencies: -)*/
#define LV_USE_LED 1
/*Line (dependencies: -*/
#define LV_USE_LINE 1
/*List (dependencies: lv_page, lv_btn, lv_label, (lv_img optionally for icons ))*/
#define LV_USE_LIST 1
#if LV_USE_LIST != 0
/*Default animation time of focusing to a list element [ms] (0: no animation) */
# define LV_LIST_DEF_ANIM_TIME 100
/*Line meter (dependencies: *;)*/
#define LV_USE_LMETER 1
/*Message box (dependencies: lv_rect, lv_btnm, lv_label)*/
#define LV_USE_MBOX 1
/*Page (dependencies: lv_cont)*/
#define LV_USE_PAGE 1
#if LV_USE_PAGE != 0
/*Focus default animation time [ms] (0: no animation)*/
# define LV_PAGE_DEF_ANIM_TIME 400
/*Preload (dependencies: lv_arc, lv_anim)*/
#define LV_USE_PRELOAD 1
#if LV_USE_PRELOAD != 0
# define LV_PRELOAD_DEF_ARC_LENGTH 60 /*[deg]*/
# define LV_PRELOAD_DEF_SPIN_TIME 1000 /*[ms]*/
# define LV_PRELOAD_DEF_ANIM LV_PRELOAD_TYPE_SPINNING_ARC
/*Roller (dependencies: lv_ddlist)*/
#define LV_USE_ROLLER 1
#if LV_USE_ROLLER != 0
/*Focus animation time [ms] (0: no animation)*/
# define LV_ROLLER_DEF_ANIM_TIME 200
/*Number of extra "pages" when the roller is infinite*/
# define LV_ROLLER_INF_PAGES 7
/*Slider (dependencies: lv_bar)*/
#define LV_USE_SLIDER 1
/*Spinbox (dependencies: lv_ta)*/
#define LV_USE_SPINBOX 1
/*Switch (dependencies: lv_slider)*/
#define LV_USE_SW 1
/*Text area (dependencies: lv_label, lv_page)*/
#define LV_USE_TA 1
#if LV_USE_TA != 0
# define LV_TA_DEF_CURSOR_BLINK_TIME 400 /*ms*/
# define LV_TA_DEF_PWD_SHOW_TIME 1500 /*ms*/
/*Table (dependencies: lv_label)*/
#define LV_USE_TABLE 1
#if LV_USE_TABLE
# define LV_TABLE_COL_MAX 12
/*Tab (dependencies: lv_page, lv_btnm)*/
#define LV_USE_TABVIEW 1
# if LV_USE_TABVIEW != 0
/*Time of slide animation [ms] (0: no animation)*/
# define LV_TABVIEW_DEF_ANIM_TIME 300
/*Tileview (dependencies: lv_page) */
#define LV_USE_TILEVIEW 1
#if LV_USE_TILEVIEW
# define LV_TILEVIEW_DEF_ANIM_TIME 300
/*Window (dependencies: lv_cont, lv_btn, lv_label, lv_img, lv_page)*/
#define LV_USE_WIN 1
* Non-user section
#if defined(_MSC_VER) && !defined(_CRT_SECURE_NO_WARNINGS) /* Disable warnings for Visual Studio*/
# define _CRT_SECURE_NO_WARNINGS
/*--END OF LV_CONF_H--*/
/*Be sure every define has a default value*/
//#include "lvgl/src/lv_conf_checker.h"
#include "lv_conf_checker.h"
#endif /*LV_CONF_H*/
and my tft_init()
* Initialize your display here
void tft_init(void)
static lv_color_t buf1[LV_HOR_RES_MAX * LV_VER_RES_MAX];
// static lv_color_t buf2[LV_HOR_RES_MAX * LV_VER_RES_MAX ];
lv_disp_buf_init(&disp_buf, buf1, NULL, LV_HOR_RES_MAX * LV_VER_RES_MAX );
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = LV_HOR_RES_MAX;
disp_drv.ver_res = LV_VER_RES_MAX;
#if TFT_EXT_FB != 0
SDRAM_Init();
LCD_Config();
DMA_Config();
disp_drv.buffer = &disp_buf;
disp_drv.flush_cb = tft_flush;
#if TFT_USE_GPU != 0
DMA2D_Config();
disp_drv.gpu_blend_cb = gpu_mem_blend;
disp_drv.gpu_fill_cb = gpu_mem_fill;
