Trying to run code below and looks like code stopes just after run line btn = lv.btn(scr)
and I don’t see any picture. What might be wrong? How to solve this problem?
import sys
import lvgl as lv
try:
lv.init()
print("start")
scr = lv.obj()
print("1")
btn = lv.btn(scr)
print("2")
btn.align(lv.scr_act(), lv.ALIGN.CENTER, 0, 0)
label = lv.label(btn)
label.set_text("Button")
lv.scr_load(scr)
print("end")
except:
print("Unexpected error:", sys.exc_info()[0])
raise
Output:
start
1
UPD
I have updated code with display driver as recommended:
import sys
import time
import lvgl as lv
lv.init()
import SDL
SDL.init()
try:
print("start")
disp_buf1 = lv.disp_buf_t()
buf1_1 = bytearray(480*10)
print("1")
disp_buf1.init(buf1_1, None, len(buf1_1)//4)
disp_drv = lv.disp_drv_t()
disp_drv.init()
disp_drv.buffer = disp_buf1
disp_drv.flush_cb = SDL.monitor_flush
disp_drv.hor_res = 480
disp_drv.ver_res = 320
disp_drv.register()
# Regsiter SDL mouse driver
indev_drv = lv.indev_drv_t()
indev_drv.init()
indev_drv.type = lv.INDEV_TYPE.POINTER;
indev_drv.read_cb = SDL.mouse_read;
indev_drv.register();
scr = lv.obj()
print("1")
btn = lv.btn(scr)
print("2")
lv.scr_load(scr)
time.sleep(5)
print("end")
except:
raise
Now it works and window blinks for 5 seconds and then program terminates. I suppose I must create loop that do not allow program terminate. How it should look?
