Hi i create button and I want the button color to change when I click on the button but esp32 reboots when I click the button on the screen
2.8inch_ESP32-2432S028R
8.3.9
static void btn_event_cb(lv_event_t* e) {
if (code == LV_EVENT_CLICKED) {
client.subscribe(mqtt_topic);
client.setCallback(callback);
if (buttonState) {
client.publish(mqtt_topic, "0");
static lv_style_t style_btn_red2;
lv_style_init(&style_btn_red2);
lv_style_set_bg_color(&style_btn_red2, lv_color_make(0, 255, 0)); // BLUE RED GREEN
lv_style_set_bg_opa(&style_btn_red2, LV_OPA_COVER);
lv_obj_add_style(btn, &style_btn_red2, 0);
} else {
client.publish(mqtt_topic, "1");
Okay, so in the code you posted the btn was never actually created, right? So you should get the pointer to the button that the event triggered, and this is done with the line I posted before.
if (buttonState) {
lv_obj_t *btn = lv_event_get_target(e); //<-- add this line here
} else {
Unless the button btn in line lv_obj_add_style(btn, &style_btn_red2, 0); is actually static
