Using a larger sized font ~16px with a text area that is set to one line with centered alignment seems to chop the bottom of the font off.
IMXRT1052
What do you experience?
I am using the text area object for a larger font. When I set the text area to use one line with centered alignment, it will chop off the bottom off larger fonts. I do see a bit different behaviour when using the simulator vs. MCU.
On the simulator, all instances of the text area are chopped off, while on the MCU, only the first instance is chopped off.
If I change the alignment to left, it renders correctly.
If the font is smaller ~8px, it renders correctly.
What do you expect?
I expect the font to be rendered whole.
void test_largefont()
static lv_style_t style_box_invisible;
lv_style_copy(&style_box_invisible, &lv_style_plain);
style_box_invisible.text.color = LV_COLOR_BLACK;
style_box_invisible.text.font = &lv_font_roboto_16;
lv_obj_t *new_ta = lv_ta_create(lv_scr_act(), NULL);
lv_mem_assert(new_ta);
lv_ta_set_cursor_type(new_ta, LV_CURSOR_NONE);
lv_ta_set_one_line(new_ta, true);
lv_ta_set_sb_mode(new_ta, LV_SB_MODE_OFF);
lv_ta_set_text_align(new_ta, LV_LABEL_ALIGN_CENTER);
lv_ta_set_style(new_ta, LV_TA_STYLE_BG, &style_box_invisible);
lv_obj_align(new_ta, NULL, LV_ALIGN_CENTER, 0, 0);
lv_ta_set_text(new_ta, "S");
