When I focus on a button in a list, the focus is not correct on that button.
STM32F407
What do you experience?
Give a detailed description. “It doesn’t work” is not enough information for us to diagnose the issue.
What do you expect?
Add a code snippet to reproduce the issue in the simulator. It should contain only the relevant code which can be compiled. Bug reports without code snippets or with erroneous code snippets will not be reviewed.
Use the ```c and ``` tags to format your code:
list_Language_config= lv_list_create(Config_screen, NULL);
// lv_obj_set_size(list_Language_config, 239, 320);
lv_obj_set_pos(list_Language_config,30, 3 5+lv_obj_get_height(list_btn[0])*Num_btn_config);
lv_obj_add_style(list_Language_config, LV_OBJ_PART_MAIN, &text_style_nomal);
/*Add buttons to the list*/
list_language_btn[0] = lv_list_add_btn(list_Language_config, NULL,"Tiếng Việt");
lv_obj_add_style(list_language_btn[0], LV_OBJ_PART_MAIN, &text_style_nomal);
lv_obj_set_event_cb(list_language_btn[0], Config_event_handler);
list_language_btn[1] = lv_list_add_btn(list_Language_config, NULL,"English");
lv_obj_add_style(list_language_btn[1], LV_OBJ_PART_MAIN, &text_style_nomal);
lv_obj_set_event_cb(list_language_btn[1], Config_event_handler);
lv_obj_set_height(list_Language_config,lv_obj_get_height(list_language_btn[0])*2);
lv_list_focus_btn(list_Language_config,list_language_btn[0]);
lv_obj_set_hidden(list_Language_config, true);
If possible, add screenshots and/or videos about the current issue.
