STM32/STM32CubeIDE
Display the tutorial hello world to start with
Built and configured to use the Sharp MIP driver as per the general porting instructions, set the flush callback, set the driver to write to the board GPIO and SPI outputs, enabled the tutorial defines, then call periodic tick forever. I’ve tried both soft and hard com inversion.
The comments at the top of SHARP_MIP.c and posting in Display drivers to share (sharp mip, uc1610) suggest that application-level changes are needed to increase the buffer size to accommodate extra fields for the SPI transmit (see snippet below). But it’s not clear what ‘X’ refers to, or what the extra defines are used for. Could a working example of the changes to buffer/driver initialisation be provided?
* VDB size : (LV_VER_RES / X) * (2 + LV_HOR_RES / 8) + 2 bytes, structure :
* [FRAME_HEADER (1 byte)] [GATE_ADDR (1 byte )] [LINE_DATA (LV_HOR_RES / 8 bytes)] 1st line
* [DUMMY (1 byte)] [GATE_ADDR (1 byte )] [LINE_DATA (LV_HOR_RES / 8 bytes)] 2nd line
* [DUMMY (1 byte)] [GATE_ADDR (1 byte )] [LINE_DATA (LV_HOR_RES / 8 bytes)] last line
* [DUMMY (2 bytes)]
* Since extra bytes (dummy, addresses, header) are stored in VDB, we need to use
* an "external" VDB. Configuration in lv_conf becomes :
* #define LV_VDB_SIZE ((LV_VER_RES / X) * LV_HOR_RES)
* #define LV_VDB_PX_BPP 1
* #define LV_VDB_ADR LV_VDB_ADR_INV
* and before lv_init() we must call lv_vdb_set_adr(our_vdb_address, NULL)
The related comment on SHARP_MIP.c has changed like this :
* an "oversized" VDB. Buffer declaration in "lv_port_disp.c" becomes for example :
* static lv_disp_buf_t disp_buf;
* static uint8_t buf[(LV_VER_RES_MAX / X) * (2 + (LV_HOR_RES_MAX / 8)) + 2];
* lv_disp_buf_init(&disp_buf, buf, NULL, LV_VER_RES_MAX * LV_HOR_RES_MAX / X);
I am seeing display corruption on the LS044Q7DH01. It doesn’t clear the screen when calling lv_obj_clean(lv_scr_act());. This screenshot is from LittlevGL tutorial lv_tutorial_objects():-
Increasing X from 2 to 32 helps with the display corruption, although only the bottom half of the buttons are filled black and I can’t clear the screen.
I don’t currently have an input driver. I’m currently looking at how a GPIO input can be used according to https://blog.littlevgl.com/2019-01-08/hardware-button, but button actions seem to have been replaced by events and it’s not working. indev_drv.read_cb updates data->state correctly when the GPIO button is pressed, but indev_drv.feedback_cb is never called.
