I have a project based on LVGL, I was using v8 according to my microcontroller’s sdk, then I had to move to v9 for bin font usage. I can use font bin file as expected but I have encountered an issue about images with using bin format. I have lots of images, I share just one. The problem is pictures look shifted on the screen. Why does that happen ?
NXP IMXRT1176
v9 with latest commits
I want see images on my screen with bin format.
I have tried it with c file, it works fine. I have added rectangle to the picture’s right side to see the effect. Because there is space in original form of picture, that’s why I could not realize it.
I have used LVGLImage.py to produce C and Bin files. raw_fs is used to read bin files from flash.
Sample code is below for producing:
python lvgl/scripts/LVGLImage.py --ofmt BIN --cf ARGB8888 --compress NONE --align 4 -o out_bin musicbackgroundicon.png
void screen_main(void)
//Write codes screen_main
lv_obj_t *screen_main = lv_obj_create(NULL);
lv_obj_set_size(screen_main, 800, 480);
lv_obj_set_scrollbar_mode(screen_main, LV_SCROLLBAR_MODE_OFF);
//Write style for screen_main, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
lv_obj_set_style_bg_opa(screen_main, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write codes _img_music
lv_obj_t *img_music = lv_img_create(screen_main);
lv_obj_add_flag(img_music, LV_OBJ_FLAG_CLICKABLE);
lv_img_set_src(img_music, "F:/musicbackgroundicon.bin");
//lv_img_set_src(img_music, &musicbackgroundicon);
lv_img_set_pivot(img_music, 50,50);
lv_img_set_angle(img_music, 0);
lv_obj_set_pos(img_music, 100, 100);
lv_obj_set_size(img_music, 174, 215);
lv_obj_set_scrollbar_mode(img_music, LV_SCROLLBAR_MODE_OFF);
//Write style for _img_music, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
lv_obj_set_style_img_recolor_opa(img_music, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_img_recolor(img_music, lv_color_hex(0x1d3248), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_img_opa(img_music, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
//Update current screen layout.
lv_obj_update_layout(screen_main);
screen_main_del = true;
You can download pictures from here
