Bg_opa doesn't work inside styles?
I’m trying to use styles, but they don’t seem to work as expected. I created a page with a single object and no widgets, and I set the background color to red using a style. However, the background appears white. If I apply the style directly to the object instead of the page, it works correctly.
It seems like the issue that background opacity isn’t getting applied through style.
esp32-s3-n16r8
v9.3
I want to utilize styles instead of copy-n-paste the same info across the objects
  1. If I have the style params applied through styles = background is white
  2. if I have the style params in the object = background is red (as expected)
  3. if I have the style params applied through styles and in addition I add opacity to the object = background is red as expected
style definition -
  temp_obj_style = new lv_style_t();
  lv_style_init(temp_obj_style);
  lv_style_set_bg_color(temp_obj_style, lv_color_make(255, 0, 0));
  lv_style_set_bg_opa(temp_obj_style, LV_OPA_COVER);
  lv_style_set_border_width(temp_obj_style, 0);
page -
   lv_obj_t_id_14 = lv_obj_create(temp_sensors_page->obj);
  lv_theme_apply_obj(lv_obj_t_id_14);
  lv_obj_add_style(lv_obj_t_id_14, temp_obj_style, LV_PART_MAIN);
  lv_obj_set_style_bg_opa(lv_obj_t_id_14, LV_OPA_COVER, LV_PART_MAIN);
  lv_obj_set_style_height(lv_obj_t_id_14, 290, LV_PART_MAIN);
  lv_obj_set_style_width(lv_obj_t_id_14, lv_pct(100), LV_PART_MAIN);
  lv_obj_set_style_x(lv_obj_t_id_14, 0, LV_PART_MAIN);
  lv_obj_set_style_y(lv_obj_t_id_14, 30, LV_PART_MAIN);
removing the following line from the page will go back to white background:
It seems like I found my issue. I had a theme for objects (lv_theme_apply_obj), which seem to overwrite the style settings. Shouldn’t it be the other way?
