Best practice moving bezel compass display on esp32-s3 waveshare 2.8 touch screen
I need to know what the best practice for implementing a frequently updated compass
indicator taking the form of a rotating disk with heading from 0 to 360 written around the
circumference.
I’m running on a Waveshare 2.8 in round display on an esp32-s3.
Lvgl 8.2.0 is what is available on this board. I’m developting with idf 5.4 from Espressif on
a modern pop! distro.
I would like either an example that rotates an image continuously or a statement of
what components (such as an image from a .png rotated via a set_angle or transform_angle
call, with specific routines mentioned) should be assembled in what fashion.
I have tried several of the animation examples and I can put a cogwheel image up but I
can’t animate its angle of rotation in real time. Calling
lv_style_set_transform_angle(&style, angle);
from within an anim callback has no effect.
I have no code running on a simulator as I’m developing on the devkitc board.
At this point I’m only asking for the basic best practice that would fit with what Lvgl supports
for a frequently updated directional gyro display.
Thanks very much,
fjen
Have you checked this compass example using lv_scale?
https://docs.lvgl.io/master/widgets/scale.html#a-round-scale-style-simulating-a-compass
