BEGINNER: lv_micropython building and useage
i make already one project with the lvgl binding from kdschlosser.
This time, i want to use the lv_micropython.
My hardware:
ILI9341 3.2 TFT, SPI 240x320 V1.0
ESP32 S3 WROOM DEV (with 2 usb ports COM/USB)
Steps:
  1. take linux laptop
  2. sudo apt-get install build-essential libreadline-dev libffi-dev git pkg-config libsdl2-2.0-0 libsdl2-dev python3.8 parallel Python 3 is required, but you can install some other version of python3 instead of 3.8, if needed.
  3. git clone https://github.com/lvgl/lv_micropython.git
  4. make -C mpy-cross
  5. make -C ports/esp32 LV_CFLAGS=ā€œ-DLV_COLOR_DEPTH=16ā€ BOARD=GENERIC_SPIRAM deploy
my questions:
how i know, the ili9341 have an DLV_COLOR_DEPTH=16 ??
what have some other displays?
i have to git clone micropython too? mpy-cross need this?
how i have to define the spi pins in the micropython programm? can you give an example?
i will use squareline studio for design the UI, is confortable and easy, then export python code and edit (or copy the UI function from the widget out)
i hope, somebody here can assist me a little bit for an next project :slight_smile:
i’m still have problems!
This is from the lv_micropython Repo:
ESP32 port
Please run esp-idf/export.sh from your ESP-IDF installation directory as explained in the Micropython ESP32 Getting Started documentation
ESP-IDF version needs to match Micropython expected esp-idf, otherwise a warning will be displayed (and build will probably fail) For more details refer to Setting up the toolchain and ESP-IDF
When using IL9341 driver, the color depth need to be set to match ILI9341. This can be done from the command line. Here is the command to build ESP32 + LVGL which is compatible with ILI9341 driver:
make -C mpy-cross
make -C ports/esp32 LV_CFLAGS="-DLV_COLOR_DEPTH=16" BOARD=GENERIC_SPIRAM deploy
Explanation about the paramters:
  • LV_CFLAGS are used to override color depth, for ILI9341 compatibility.
    • LV_COLOR_DEPTH=16 is needed if you plan to use the ILI9341 driver.
  • BOARD - I use WROVER board with SPIRAM. You can choose other boards from ports/esp32/boards/ directory.
  • deploy - make command will create ESP32 port of Micropython, and will try to deploy it through USB-UART bridge.
I make already everything from the ESP-IDF:
my last command was: . ./export.sh
and now? i have to clone the micrpython Repo ? or the lv_micropython Repo ? and make this in any kind together with make -C mpy-cross ?
it would be nice, when somebody can explain is to me (I’m a beginner) and maybe edit the lv_micropython Documentation in the Repo…
Greetings
Fabse
I have similar questions. After spending 2 days with ChatGPT trying to install for Mac OSX Ventura - I found myself in a never ending loop of incomplete files, make requirements, etc.
While I would love to find out what LVGL can do (I’m working in MicroPython / Pico environment), I’m dead in the water at this point just getting to try it out. Seems like there should be an easier way (not clear from the docs).
Thanks if anyone can offer answers.
I’m not the only one … THANKS
After much messing around, I was able to finally get lvgl ā€˜recognized’ on Mac OSX by restarting the instructions, and finding that the lv_micropython ended up being in the directory ./ports/unix/build-standard for my build (adding the build-standard directory). I then linked this with
ln -s $(pwd)/micropython /usr/local/bin/lv_micropython
(Thanks to ChatGPT). I am now able to see lv_micropython and run it from the main shell. In the REPL (>>>) I am able to import lvgl:
import lvgl as lv
And it doesn’t complain (which is great).
BUT…
I want to load lvgl into my Pico so I can actually use it with displays. I followed the directions using the make -C mpy-cross then
make -j -C ports/rp2 BOARD=PICO USER_C_MODULES=…/…/lib/lv_bindings/bindings.cmake
to create the firmware.utf (which gets created in ./ports/rp2/build-PICO) and flashed it successfully to the Pico microcontroller.
I fire up Thonny IDE and set my target to the Pico and tested the connection with a Blinky.py program. Then when I attempt to import lvgl as ly, it companies with ā€˜no module named lvgl’
I must still be missing something fundamental/simple
I had thought the lvgl would be included in the firmware build, but apparently not (or I’m not correctly importing it).
Seems like this all might be easier if there were simply a library to download and import (like we do for display drivers for example), then make sure it is loaded with our other drivers onto our project boards. (or perhaps it is entirely possible that I don’t know enough to know what I’m talking about :slight_smile: )
Hi all,
Just signed up here because I’m also interested in using LVGL with Micropython.
I’m not an absolute beginner in electronics and programming but building firmware on Linux in the CLI is beyond my skills. I really have no idea where to start and reading issues above make me refrain from trying anything in the first place.
Don’t get me wrong, I’m not complaining.
Is there maybe something like ā€œa complete idiots guideā€ or an ā€œexplain it to me like I’m 5 guideā€ on the topic of building firmware to use LVGL in Micropython?
At this point I feel like a somewhat advanced beginner who lacks the knowledge to progress to more advanced topics.
Thanks for reading!
Hence the reason why I wrote the lvgl_micropython binding. The official one has too many inconsistencies and quirks in it and can be a pain to get running correctly. It’s not cut and dry.
yes, you 100% right.
The best is: GitHub - lvgl/lv_micropython: Micropython bindings to LVGL for Embedded devices, Unix and JavaScript
The ā€œIssueā€ Tab is disabled and here in the Forum is no support too.
So, i will work with your solution again :smiley:
Because, everybody know: The Projects never stops!
This is where you need to open issues for the official MicroPython binding.
okay, thanks.
When i going to it, if have more questions:
why there are 2 Repos, how they connect together? why is one the sub repo ?
and how i build this everything together?
Thanks for this.
I think one of the challenges that is confusing people (well… me at least) is that the documentation seems to jump around between the different repositories (lv_micropythion and lv_binding_micropython), making it extremely likely the reader will get lost and give up.
(Spoiler Alert: I apologize in advance if this sounds like I’m whining… I’m really not. I’m coming at this from the perspective of a n00b who is interested in helping other n00bs (students age 14 and up) learn to code meaningful projects and noting that it can be extremely confusing and difficult to get from point A to point B in getting up and running :slight_smile: )
For example:
Folliwing the instructions at the link you provided (MANY THANKS FOR THAT!!):
I was able to successfully install lv_microptyon and build the firmware.utf for the PICO board. (A previous attempt appeared to create the .utf, but upon BOOTSEL install, it didn’t do anything and did not complain, so I was in the dark as to why it had failed). My second attempt being successful, I loaded it to Pico and tried the sample code in that documentation:
import lvgl as lv
lv.init()
and it ran without complaint. Great! it seems to be recognized and working! I’m on the way!
The next instruction:
" Then event loop, display driver and input driver needs to be registered. Refer to Porting the library for more information. Here is an example of registering SDL drivers on Micropython unix port:
# Create an event loop and Register SDL display/mouse/keyboard drivers.
from lv_utils import event_loop
Up to this point there hasn’t been mention of the lv_utils.py library file, so adding this line to a test file fails as the lv_utlis library is not found.
And so begins the wild adventure through documentation that bounces between the C and MicroPython sites, passing through various pages, offshoots, opening browser tabs (some for pages already open).
Eventually (I think it was after a google search) I found lv_utils.py on GitHub in the ā€œotherā€ repository for lv_binding_micropython:
(I’m still not sure how I actually found it.) Do I now pul that entire lib directory into my project even though I found it at lv_bindings_micropython instead of lv_micropython?
Copying the lv_utils to my project file helped n that it satisfied the IDE that the library is no longer missing, but I haven’t any idea if that means I’m good to go or if there will be (many) more similar excursions before I get to a functional .py file.
I hope this sheds some light as I know once you’ve been working in a paradigm for a while, learning much along the way, it can be difficult to remember what the absolute n00b is facing, possibly with less baseline understanding about what is going on.
I hope that is helpful.
@Quisp
If you want something easy to use you can try out LVGL MicroPython. This is an offshoot of LV MicroPython. It is something I have been working on that simplifies the build process, makes it a lot easier to stay up to date with MicroPython version releases and I have hammered out a framework for the display drivers, touch drivers, and the different connection methods to those devices.
Presently it works with the ESP32 series of MCU’s. It also works on Linux and macOS. I can get it working with on STM32 and also on the RP2 but with limited abilities. I need someone that knows more about those MCU’s that would be willing to help with providing the full feature set. Presently those MCU’s It is not working.
Check it out if you want, I personally feel it is a step in the right direction and it makes things a lot easier for the user to be able to get up and running very quickly.
