Axes on chart widget
I want to draw two graphs in an XY-coordinate system on a 800x480 pixel TFT.
My board is custom made based on the ESP32S3 processor.
Version 9.2
I perfectly looking XY-coordinate system with two graphs.
I use the graph widget for the graphs and the scale widget for the x-ais and for the Y-axis. I set about 10 division lines in graph. I set tick marks using scale. That is all fine.
My problem is how to align the axes to the graph. I have fiddled for a long time changing the position and the size by one or two pixels at a time. I have achieved a useable result, but there must be a more elegant way, but how?
I call lv_obj_set_size, lv_obj_set_align and lv_obj_set_pos. Then I use cut and try adding or subtracting a few pixels to make the best match between chart and the two axes, but that is rather time consuming, hence my thought is that there is a smarter way to get the right position and lengths of the axis.
How???
Regards,
Jorgen
maybe you can use lv_obj_set_style_pad_hor(scale_bottom, lv_chart_get_first_point_center_offset(chart), 0);
Yes, that is included in one of the examples, but it is for the x-axis only and it refers to the mid-point. I want to align to the point where the x-axis and the y-axis cross each other.
Regards,
