Using the example code for the Simple watch (Batman dial) shipped with the TTGO T-watch library. I have replaced the watch face, re positioned the time display, changed the font and removed the seconds count.
I want to rotate an image of a pointer to represent seconds. I’ve created the pointer image (img2), positioned it and can rotate it with lv_image_set_angle().
The code i’m reusing creates an lv_task to update on screen elements.
Trying to change image angle within the task fails with “img2 not captured”
Trying to change the angle within the main loop between lv_task_handler calls, compiles but the screen is then blank.
I’ve also placed the image angle change into its own routine and calling it from the task and the main loop. This gives a blank screen in both cases.
Lily-Go T-Watch with Arduino 1.8.19
Twatch distribution. LVGL V 7
A rotating second hand from an image over a watch face from an image
LV_IMG_DECLARE(raym); //watch face
LV_IMG_DECLARE(pointer); /second hand
void setup()
watch = TTGOClass::getWatch();
watch->begin();
watch->lvgl_begin();
lv_obj_t *img1 = lv_img_create(lv_scr_act(), NULL);
lv_obj_t *img2 = lv_img_create(lv_scr_act(),NULL);
lv_img_set_src(img1, &raym);
lv_img_set_src(img2, &pointer);
lv_img_set_pivot (img2, 8, 120);
lv_obj_align(img1, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_align(img2, NULL, LV_ALIGN_CENTER,0,-50);
/* Block of formatting for text removed for clarity*/
lv_img_set_angle(img2,2800); //--------------- This works OK
lv_task_create([](lv_task_t *t) {
RTC_Date curr_datetime = rtc->getDateTime();
lv_img_set_angle(img2,300);//------- This fails with "img2 is not captured" ---------------
lv_label_set_text_fmt(g_data.minute, "%02u", curr_datetime.minute);
lv_label_set_text_fmt(g_data.hour, "%02u:", curr_datetime.hour);
}, 1000, LV_TASK_PRIO_MID, nullptr);
void loop()
//lv_img_set_angle(img2, 300); //------------ this results in blank screen -----------------
lv_task_handler();
