Since LVGL was “crashing” due to the fact that my LV_MEM_SIZE was too small I tried increasing this size by moving the memory buffer for LVGL.
But now all I get is the following.
[Error] (0.310, +310) insert_free_block: Asserted at expression: current && “free list cannot have a null entry” (in lv_tlsf.c line #614)
My original memory map looked like this
+------------ 0x20003900 ------------+
| eventrecorder (1280 bytes) |
+------------ 0x20003E00 ------------+
+------------ 0x20004100 ------------+
| LVGL memory (16128 bytes) |
+============ 0x20008000 ============+
| Controller internal |
+============ 0xA0000000 ============+
And, by removing the eventrecorder (part of the keil uVision) my new memory map should look like this.
| LVGL memory (18176 bytes) |
And lv_conf (original)
/*1: use custom malloc/free, 0: use the built-in `lv_mem_alloc()` and `lv_mem_free()`*/
#define LV_MEM_CUSTOM 0
#if LV_MEM_CUSTOM == 0
#define LV_MEM_SIZE 0x3F00 //(64U * 1024U) /*[bytes]*/
#define LV_MEM_ADR 0x20004100 /*0: unused*/
#if LV_MEM_ADR == 0
#undef LV_MEM_POOL_INCLUDE
#undef LV_MEM_POOL_ALLOC
#else /*LV_MEM_CUSTOM*/
#define LV_MEM_CUSTOM_INCLUDE <stdlib.h> /*Header for the dynamic memory function*/
#define LV_MEM_CUSTOM_ALLOC malloc
#define LV_MEM_CUSTOM_FREE free
#define LV_MEM_CUSTOM_REALLOC realloc
#endif /*LV_MEM_CUSTOM*/
And the new version
#define LV_MEM_SIZE 0x4700 //(64U * 1024U) /*[bytes]*/
#define LV_MEM_ADR 0x20003900 /*0: unused*/
#if LV_MEM_ADR == 0
An LPC1788 with keil uVision and LVGL 8.4.0 (was 8.3.11)
A bigger LV_MEM_SIZE
Nothing really, I just changed my LV_MEM_SIZE and LV_MEM_ADR, next I know 2 of the asserts where failing.
The 1st was
tlsf_assert(block_to_ptr(block) == align_ptr(block_to_ptr(block), ALIGN_SIZE)
&& "block not aligned properly");
Next the current assert is also failing
tlsf_assert(current && "free list cannot have a null entry");
No real steps required. I have the LV_USE_MEM_MONITOR enabled so I can keep tabs on the memory usage. But when I now start the LVGL thread the memory monitor only displays a ? followed by a assert crash at the above mentioned locations.
