Arosto_de_medici
coffee roaster program, will use bang bang control for temp regulation, 3 thermisters, touchscreen TFT, start/stop button, etc etc
using a Pico 2
trying to get EEZ studio code running on the RPI
searched forums, used AI, etc to try and get the code to run, cant seem to get past so many errors in arduino IDE
below is the basic example from LVGL, it will not compile on my machine as it sits.
/*/*Using LVGL with Arduino requires some extra steps:
*Be sure to read the docs here: https://docs.lvgl.io/master/get-started/platforms/arduino.html */
#include <lvgl.h>
#include <TFT_eSPI.h>
/*To use the built-in examples and demos of LVGL uncomment the includes below respectively.
*You also need to copy lvgl/examples to lvgl/src/examples. Similarly for the demos lvgl/demos to lvgl/src/demos.
Note that the lv_examples library is for LVGL v7 and you shouldn’t install it for this version (since LVGL v8)
as the examples and demos are now part of the main LVGL library. */
/Change to your screen resolution/
static const uint16_t screenWidth = 480;
static const uint16_t screenHeight = 320;
static lv_color_t buf[ screenWidth * 10 ];
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char * buf)
Serial.printf(buf);
Serial.flush();
/* Display flushing */
void my_disp_flush( lv_disp_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
lv_disp_flush_ready( disp );
/Read the touchpad/
void my_touchpad_read( lv_indev_t * indev_driver, lv_indev_data_t * data )
uint16_t touchX, touchY;
bool touched = tft.getTouch( &touchX, &touchY, 600 );
if( !touched )
    /*Set the coordinates*/
    data->point.x = touchX;
    data->point.y = touchY;
    Serial.print( "Data x " );
    Serial.println( touchX );
    Serial.print( "Data y " );
    Serial.println( touchY );
void setup()
Serial.begin( 115200 ); /* prepare for possible serial debug */
LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
Serial.println( LVGL_Arduino );
Serial.println( "I am LVGL_Arduino" );
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print ); /* register print function for debugging */
tft.begin();          /* TFT init */
tft.setRotation( 3 ); /* Landscape orientation, flipped */
/*Set the touchscreen calibration data,
 the actual data for your display can be acquired using
 the Generic -> Touch_calibrate example from the TFT_eSPI library*/
uint16_t calData[5] = { 275, 3620, 264, 3532, 1 };
tft.setTouch( calData );
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * 10 );
/*Initialize the display*/
static lv_disp_t disp_drv;
/*Change the following line to your display resolution*/
lv_disp_drv_register( &disp_drv );
static lv_indev_t indev_drv;
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
#if 0
/* Create simple label */
lv_obj_t label = lv_label_create( lv_scr_act() );
lv_label_set_text( label, LVGL_Arduino.c_str() );
lv_obj_align( label, LV_ALIGN_CENTER, 0, 0 );
#else
Try an example from the lv_examples Arduino library
make sure to include it as written above.
lv_example_btn_1();
// uncomment one of these demos
lv_demo_widgets();            // OK
// lv_demo_benchmark();          // OK
// lv_demo_keypad_encoder();     // works, but I haven't an encoder
// lv_demo_music();              // NOK
// lv_demo_printer();
// lv_demo_stress();             // seems to be OK
Serial.println( “Setup done” );
void loop()
delay( 5 );
## Screenshot and/or video
