Arduino example code does not compile!
This is stupid why would example code not compile, things change but doesn’t any one maintain the code examples?
loading library from c:\Users\Ralph\Documents\Arduino\libraries\Dump: invalid library: no header files found
FQBN: arduino:mbed_giga:giga
Using board 'giga' from platform in folder: C:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1
Using core 'arduino' from platform in folder: C:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1
Detecting libraries used...
C:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @C:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\variants\GIGA/defines.txt @C:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\variants\GIGA/cxxflags.txt -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_GIGA -DARDUINO_ARCH_MBED_GIGA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -IC:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\cores\arduino -IC:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\variants\GIGA -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 -IC:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\cores\arduino/api/deprecated -IC:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\cores\arduino/api/deprecated-avr-comp -iprefixC:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\cores\arduino @C:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\variants\GIGA/../GIGA/includes.txt C:\Users\Ralph\AppData\Local\Temp\arduino\sketches\DC2321A7D97B37D634E842F20EA24513\sketch\LVGL_Arduino.ino.cpp -o nul
Alternatives for lvgl.h: [lvgl@9.1.0]
ResolveLibrary(lvgl.h)
-> candidates: [lvgl@9.1.0]
C:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @C:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\variants\GIGA/defines.txt @C:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\variants\GIGA/cxxflags.txt -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_GIGA -DARDUINO_ARCH_MBED_GIGA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -IC:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\cores\arduino -IC:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\variants\GIGA -Ic:\Users\Ralph\Documents\Arduino\libraries\lvgl\src -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 -IC:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\cores\arduino/api/deprecated -IC:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\cores\arduino/api/deprecated-avr-comp -iprefixC:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\cores\arduino @C:\Users\Ralph\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\variants\GIGA/../GIGA/includes.txt C:\Users\Ralph\AppData\Local\Temp\arduino\sketches\DC2321A7D97B37D634E842F20EA24513\sketch\LVGL_Arduino.ino.cpp -o nul
In file included from c:\users\ralph\documents\arduino\libraries\lvgl\src/lv_init.h:16:0,
from c:\users\ralph\documents\arduino\libraries\lvgl\lvgl.h:24,
from c:\Users\Ralph\Documents\Arduino\libraries\lvgl\src/lvgl.h:16,
from C:\Users\Ralph\Documents\Arduino\GIGA\Display\LVGL\LVGL_Arduino\LVGL_Arduino.ino:5:
c:\users\ralph\documents\arduino\libraries\lvgl\src/lv_conf_internal.h:59:18: fatal error: ../../lv_conf.h: No such file or directory
#include "../../lv_conf.h" /*Else assume lv_conf.h is next to the lvgl folder*/
compilation terminated.
Alternatives for ../../lv_conf.h: []
ResolveLibrary(../../lv_conf.h)
-> candidates: []
exit status 1
Compilation error: exit status 1
