The arc is convex at both ends
lvgl 9.2
NXP smartwatch seem ok.(lvgl 8.3)
My demo is base in lvgl9.2.
lv_obj_t* h_arc = lv_arc_create(parent); // 创建湿度圆弧
lv_arc_set_mode(h_arc, LV_ARC_MODE_NORMAL);
lv_arc_set_range(h_arc, 0, 100); // 设置圆弧 数值范围
lv_arc_set_value(h_arc, 50); // 设置圆弧 当前值
lv_obj_clear_flag(h_arc, LV_OBJ_FLAG_CLICKABLE); // 禁止点击事件
lv_obj_remove_style(h_arc, NULL, LV_PART_KNOB); // 移除圆弧手柄
lv_arc_set_rotation(h_arc, 0);
lv_obj_set_size(h_arc, SLIDE_VALUE_D, SLIDE_VALUE_D); // 设置圆大小
lv_obj_set_pos(h_arc, (LCD_W-SLIDE_VALUE_D)/2, (LCD_W-SLIDE_VALUE_D)/2);// 设置圆位置
//lv_arc_set_angles(h_arc, 360-15, 15); // 设置前景弧角度范围
lv_arc_set_bg_angles(h_arc, 360-15, 15); // 设置背景弧角度范围
//Write style for home_digital_arc_flash, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
lv_obj_set_style_bg_opa(h_arc, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_border_width(h_arc, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_arc_width(h_arc, 6, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_arc_opa(h_arc, 255*3/10, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_arc_color(h_arc, lv_color_hex(0xC8A46C), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_radius(h_arc, 6, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_top(h_arc, 4, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(h_arc, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_left(h_arc, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_right(h_arc, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_width(h_arc, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write style for home_digital_arc_flash, Part: LV_PART_INDICATOR, State: LV_STATE_DEFAULT.
lv_obj_set_style_arc_width(h_arc, 6, LV_PART_INDICATOR|LV_STATE_DEFAULT);
lv_obj_set_style_arc_opa(h_arc, 255, LV_PART_INDICATOR|LV_STATE_DEFAULT);
lv_obj_set_style_arc_color(h_arc, lv_color_hex(0xC8A46C), LV_PART_INDICATOR|LV_STATE_DEFAULT);
//Write style for home_digital_arc_flash, Part: LV_PART_KNOB, State: LV_STATE_DEFAULT.
lv_obj_set_style_bg_opa(h_arc, 0, LV_PART_KNOB|LV_STATE_DEFAULT);
lv_obj_set_style_pad_all(h_arc, 0, LV_PART_KNOB|LV_STATE_DEFAULT);
