According to the docs regarding the default group:
Set a default group. New object are added to this group if it’s enabled in their class with
add_to_def_group = true
Now this is inaccurate, it’s actually a field in the class spec called group_def and it needs to be set to a specific enum constant:
.group_def = LV_OBJ_CLASS_GROUP_DEF_TRUE,
to enable adding to the default group. Leaving that aside, the issue I ran into is that as far as I can tell all the widgets that might need a group have this set, except for arc. Is there any good reason that arc should not be added to the default group, at least if it’s adjustable?
