Hello LVGL Community,
I’m experiencing persistent segmentation faults in my application built with LVGL version 9.1.0 using EEZ Studio. When I compile and load it on my embedded system, the application initializes correctly and is fully interactive—allowing screen switches and widget interactions—until I add one or two additional widgets. At that point, the application crashes with a segfault before even loading the first screen. Right now I might in theory just make changes to how things work and fix it, but I’m worried that if I keep going I’ll eventually reach a point where I can’t complete the project as it will just be infinitely unstable with each minor change. Something feels very wrong here, and I’m hoping for some community help.
Here’s a summary of what’s happening:
Environment:
- LVGL Version: 9.1.0
- Development Tool: EEZ Studio to build front end
- Hardware: Beaglebone Green
- OS: Custom Yocto Linux Build
- Fonts Tested: Built-in stock fonts and custom fonts
Behavior:
- Initial State: Application starts, interactive, screens and widgets function as expected.
- After Adding Widgets:
- Adding one or two new widgets causes the application to segfault before loading any screen.
- Removing one widget allows the application to start, but interacting with the remaining widget leads to a segfault.
- Segfaults occur within LVGL library code, as confirmed by GDB and stack traces. And always in different places depending on what tweaks I make to the layout / code.
Attempts to Resolve:
- Tried both stock and custom fonts without success.
- Moved the problematic widgets to a separate screen, but the application still segfaults consistently.
Questions:
- Are there any known limitations or common issues with LVGL 9.1.0 that could cause these segfaults when adding multiple widgets?
- Could this be related to memory management or resource allocation within EEZ Studio when handling additional widgets?
- Are there specific debugging steps or tools you recommend to pinpoint the exact cause within the library code?
Additional Information:
- I have examined the stack traces using GDB, and the segfaults occur within the LVGL library functions. However, I haven’t been able to identify the root cause.
- The issue persists regardless of whether the widgets are on the same screen or moved to a different one.
What I’ve Tried So Far:
- Using Stock Fonts: No change in behavior.
- Using Custom Fonts: Same issue persists.
- Removing Widgets Individually: Application starts with one widget but crashes upon interaction. Both widgets just crash it immediately.
- Moving Widgets to a New Screen: Still results in continuous segfaults.
- Changing styling: I have tried totally restyling the widgets in a variety of ways, as it seems often like its a fault related to applying a style to the widgets.
Any insights or suggestions would be greatly appreciated!
Here is an example stack trace of a segfault with both of the new widgets on the screen:
update_obj_state (obj=0xb6d3feb8 <work_mem_int+64632>, new_state=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_obj.c:772
warning: Source file is more recent than executable.
772 ts[tsi].delay = tr->delay;
(gdb) bt
#0 update_obj_state (obj=0xb6d3feb8 <work_mem_int+64632>, new_state=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_obj.c:772
#1 0xb6ce9656 in lv_obj_event_base (class_p=class_p@entry=0xb6d2f074 <lv_textarea_class>, e=e@entry=0xbefff9e0) at /usr/src/debug/lvgl/9.1.0/src/core/lv_obj_event.c:86
#2 0xb6d27f0c in lv_textarea_event (class_p=<optimized out>, e=0xbefff9e0) at /usr/src/debug/lvgl/9.1.0/src/widgets/textarea/lv_textarea.c:890
#3 0xb6ce9656 in lv_obj_event_base (class_p=class_p@entry=0x0, e=e@entry=0xbefff9e0) at /usr/src/debug/lvgl/9.1.0/src/core/lv_obj_event.c:86
#4 0xb6ce96a2 in event_send_core (e=e@entry=0xbefff9e0) at /usr/src/debug/lvgl/9.1.0/src/core/lv_obj_event.c:359
#5 0xb6ce973a in lv_obj_send_event (obj=obj@entry=0xb6d3feb8 <work_mem_int+64632>, event_code=event_code@entry=LV_EVENT_SCROLL_BEGIN, param=param@entry=0xbefffa14)
at /usr/src/debug/lvgl/9.1.0/src/core/lv_obj_event.c:64
#6 0xb6cebf7c in lv_obj_scroll_by (anim_en=<optimized out>, dy=<optimized out>, dx=<optimized out>, obj=0xb6d3feb8 <work_mem_int+64632>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_obj_scroll.c:339
#7 lv_obj_scroll_by (obj=0xb6d3feb8 <work_mem_int+64632>, dx=<optimized out>, dy=<optimized out>, anim_en=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_obj_scroll.c:304
#8 0xb6d27432 in lv_textarea_set_cursor_pos (obj=obj@entry=0xb6d3feb8 <work_mem_int+64632>, pos=<optimized out>, pos@entry=32767) at /usr/src/debug/lvgl/9.1.0/src/widgets/textarea/lv_textarea.c:388
#9 0xb6d27c08 in lv_textarea_set_text (obj=obj@entry=0xb6d3feb8 <work_mem_int+64632>, txt=0x415900 "999999") at /usr/src/debug/lvgl/9.1.0/src/widgets/textarea/lv_textarea.c:294
#10 0x00408c48 in create_screen_settings () at /mnt/c/Users/danie/ClionProjects/HandController/src/ui/screens.c:2255
#11 0x004092b0 in create_screens () at /mnt/c/Users/danie/ClionProjects/HandController/src/ui/screens.c:2429
#12 0x0040964c in ui_init () at /mnt/c/Users/danie/ClionProjects/HandController/src/ui/ui.c:57
#13 0x00402ae0 in main () at /mnt/c/Users/danie/ClionProjects/HandController/main.c:187
And here is the code up until the lv_text_area_set_text() line that is triggering the cascade of the crash. No removing the set_text from the text entry box does not help, it just moves the segfault elsewhere.
lv_obj_t *obj = lv_obj_create(parent_obj);
lv_obj_set_pos(obj, -35, -32);
lv_obj_set_size(obj, 148, 58);
lv_obj_set_style_pad_left(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_pad_top(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_pad_right(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_border_width(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_radius(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_t *parent_obj = obj;
lv_obj_t *obj = lv_label_create(parent_obj);
lv_obj_set_pos(obj, 0, 0);
lv_obj_set_size(obj, LV_SIZE_CONTENT, LV_SIZE_CONTENT);
lv_label_set_text(obj, "Serial Number");
lv_obj_set_style_text_font(obj, &ui_font_roboto_16_bold, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_t *obj = lv_textarea_create(parent_obj);
lv_obj_set_pos(obj, 0, 18);
lv_obj_set_size(obj, 147, 35);
lv_textarea_set_max_length(obj, 20);
lv_textarea_set_text(obj, "999999");
This is what the screen in question looks like, the widgets that cause the problem are the box with limits, and the model/serial/software panels.
Here is an example of a segfault stack trace when only one of the widgets is gone, seems to be related to a character being drawn on the screen:
(gdb) bt
#0 0xb6cf3d42 in draw_letter (cb=<optimized out>, letter=98, font=<optimized out>, pos=<synthetic pointer>, dsc=0xbeffef50, draw_unit=<optimized out>)
at /usr/src/debug/lvgl/9.1.0/src/draw/lv_draw_label.c:419
#1 lv_draw_label_iterate_characters (draw_unit=0xb6d30ed8 <work_mem_int+3224>, dsc=0xb6d3bc9c <work_mem_int+47708>, coords=0xb6d3c720 <work_mem_int+50400>, cb=0xb6cfb1a5 <draw_letter_cb>)
at /usr/src/debug/lvgl/9.1.0/src/draw/lv_draw_label.c:328
#2 0xb6cfb2da in lv_draw_sw_label (draw_unit=draw_unit@entry=0xb6d30ed8 <work_mem_int+3224>, dsc=<optimized out>, coords=coords@entry=0xb6d3c720 <work_mem_int+50400>)
at /usr/src/debug/lvgl/9.1.0/src/draw/sw/lv_draw_sw_letter.c:57
#3 0xb6cf8408 in execute_drawing (u=0xb6d30ed8 <work_mem_int+3224>) at /usr/src/debug/lvgl/9.1.0/src/draw/sw/lv_draw_sw.c:377
#4 execute_drawing_unit (u=0xb6d30ed8 <work_mem_int+3224>) at /usr/src/debug/lvgl/9.1.0/src/draw/sw/lv_draw_sw.c:245
#5 dispatch (layer=0xb6d3133c <work_mem_int+4348>, draw_unit=0xb6d30ed8 <work_mem_int+3224>) at /usr/src/debug/lvgl/9.1.0/src/draw/sw/lv_draw_sw.c:325
#6 dispatch (draw_unit=0xb6d30ed8 <work_mem_int+3224>, layer=0xb6d3133c <work_mem_int+4348>) at /usr/src/debug/lvgl/9.1.0/src/draw/sw/lv_draw_sw.c:292
#7 0xb6cf1da4 in lv_draw_dispatch_layer (disp=disp@entry=0xb6d31020 <work_mem_int+3552>, layer=layer@entry=0xb6d3133c <work_mem_int+4348>) at /usr/src/debug/lvgl/9.1.0/src/draw/lv_draw.c:255
#8 0xb6cf1edc in lv_draw_dispatch () at /usr/src/debug/lvgl/9.1.0/src/draw/lv_draw.c:161
#9 0xb6cf1f4a in lv_draw_finalize_task_creation (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, t=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/draw/lv_draw.c:138
#10 0xb6cf3652 in lv_draw_label (coords=0xbefff038, dsc=0xbefff068, layer=0xb6d3133c <work_mem_int+4348>) at /usr/src/debug/lvgl/9.1.0/src/draw/lv_draw_label.c:97
#11 0xb6d1e85c in draw_main (e=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/widgets/label/lv_label.c:779
#12 lv_label_event (class_p=<optimized out>, e=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/widgets/label/lv_label.c:712
#13 lv_label_event (class_p=<optimized out>, e=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/widgets/label/lv_label.c:663
#14 0xb6ce9656 in lv_obj_event_base (class_p=class_p@entry=0x0, e=e@entry=0xbefff100) at /usr/src/debug/lvgl/9.1.0/src/core/lv_obj_event.c:86
#15 0xb6ce96a2 in event_send_core (e=e@entry=0xbefff100) at /usr/src/debug/lvgl/9.1.0/src/core/lv_obj_event.c:359
#16 0xb6ce973a in lv_obj_send_event (obj=obj@entry=0xb6d340b4 <work_mem_int+15988>, event_code=event_code@entry=LV_EVENT_DRAW_MAIN, param=param@entry=0xb6d3133c <work_mem_int+4348>)
#17 0xb6cef6e2 in lv_obj_redraw (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d340b4 <work_mem_int+15988>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:110
#18 0xb6cef9ca in refr_obj (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d340b4 <work_mem_int+15988>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:892
#19 0xb6cef75c in refr_obj (obj=0xb6d340b4 <work_mem_int+15988>, layer=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:888
#20 lv_obj_redraw (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d33ef0 <work_mem_int+15536>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:161
#21 0xb6cef9ca in refr_obj (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d33ef0 <work_mem_int+15536>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:892
#22 0xb6cef75c in refr_obj (obj=0xb6d33ef0 <work_mem_int+15536>, layer=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:888
#23 lv_obj_redraw (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d33e3c <work_mem_int+15356>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:161
#24 0xb6cef9ca in refr_obj (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d33e3c <work_mem_int+15356>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:892
#25 0xb6cef75c in refr_obj (obj=0xb6d33e3c <work_mem_int+15356>, layer=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:888
#26 lv_obj_redraw (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d33bb8 <work_mem_int+14712>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:161
#27 0xb6cef9ca in refr_obj (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d33bb8 <work_mem_int+14712>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:892
#28 0xb6cef75c in refr_obj (obj=0xb6d33bb8 <work_mem_int+14712>, layer=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:888
#29 lv_obj_redraw (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d33aa4 <work_mem_int+14436>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:161
#30 0xb6cef9ca in refr_obj (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d33aa4 <work_mem_int+14436>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:892
#31 0xb6cef75c in refr_obj (obj=0xb6d33aa4 <work_mem_int+14436>, layer=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:888
#32 lv_obj_redraw (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d339c4 <work_mem_int+14212>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:161
#33 0xb6cef9ca in refr_obj (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d339c4 <work_mem_int+14212>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:892
#34 0xb6cef75c in refr_obj (obj=0xb6d339c4 <work_mem_int+14212>, layer=<optimized out>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:888
--Type <RET> for more, q to quit, c to continue without paging--bt
#35 lv_obj_redraw (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d33350 <work_mem_int+12560>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:161
#36 0xb6cef9ca in refr_obj (layer=layer@entry=0xb6d3133c <work_mem_int+4348>, obj=obj@entry=0xb6d33350 <work_mem_int+12560>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:892
#37 0xb6cefde0 in refr_obj (obj=0xb6d33350 <work_mem_int+12560>, layer=0xb6d3133c <work_mem_int+4348>) at /usr/src/debug/lvgl/9.1.0/src/core/lv_refr.c:826
