Anyone know how to rename a tabview tab after its been created?
Id like to rename a tabview tab after it has been created
Arduino/ESP32
8.2
As description
    //Update Tab name and Light Label
    lv_obj_t * tab_btns = lv_tabview_get_tab_btns(tv);
    char __lightName[sizeof(lightName)];
    lightName.toCharArray(__lightName, sizeof(lightName));
    const char * map[] = {LV_SYMBOL_HOME, "Temps", "Heating", "Backlight", __lightName, "Info", ""};
    lv_btnmatrix_set_map(tab_btns, map);
As above
The commented out section caused a reset, not really what I was hoping for…
Any help would be appreciated
Hi @elgerg ,
I’m sorry but I don’t think there is a way currently to do this unfortunately. Unless @kisvegabor or @embeddedt have any suggestions? The reason it is crashing is because the map[] array needs to be static or global as it is used by reference and not copied to the widgets internals. It’s not elegant but if you have a finite number of ‘__lightNames’ you could define multiple static maps and assign those?
For example:
static const char * map1[] = {LV_SYMBOL_HOME, "Temps", "Heating", "Backlight", "Light 1", "Info", ""};
static const char * map2[] = {LV_SYMBOL_HOME, "Temps", "Heating", "Backlight", "Light 2", "Info", ""};
static const char * map3[] = {LV_SYMBOL_HOME, "Temps", "Heating", "Backlight", "Light 3", "Info", ""};
static const char * map4[] = {LV_SYMBOL_HOME, "Temps", "Heating", "Backlight", "Light 4", "Info", ""};
Apart from that it might be worth considering a different approach maybe?
I hope that is helpful!
Kind Regards,
Pete
Hi Pete,
Thanks for looking into this for me. Unfortunately I do not know beforehand what these names might be. They are supplied by the user using a web form and can be anything. I’d rather not have to pre-think of all of the names and create arrays for every possibility and then re-compile when another name comes up.
If the only option I have would be on initialization then when the form is saved I can reboot the ESP but being able to change the names dynamically would be great.
Thanks
Alex
Hi Alex (@elgerg ),
Here is a real hacky solution but it might get you out of trouble!
    /* Create tabview  */
    tv = lv_tabview_create(lv_scr_act(), LV_DIR_TOP, 50);
    lv_obj_t * tab1 = lv_tabview_add_tab(tabview, LV_SYMBOL_HOME);
    lv_obj_t * tab2 = lv_tabview_add_tab(tabview, "Temps");
    lv_obj_t * tab3 = lv_tabview_add_tab(tabview, "Heating");
    lv_obj_t * tab4 = lv_tabview_add_tab(tabview, "Backlight");
    lv_obj_t * tab5 = lv_tabview_add_tab(tabview, __lightName);
    lv_obj_t * tab6 = lv_tabview_add_tab(tabview, "Info");
    /* Code to update tab when __lightName is changed... */
	lv_tabview_t *tvp = (lv_tabview_t *)tv;
	tvp->map[4] = __lightName;
	lv_obj_invalidate(tv);
I hope this works for you!
Kind Regards,
Pete
Hi Pete,
I love a good hack!
So the solution is mostly working but I have a slight problem in that I end up with C? instead of the string > char that is specified. It’s probably something I’m missing.
I’m using the Arduino environment for the ESP32 and have the following:
Where lightname is a String…
Any idea what stupid mistake I’ve made?
Thanks in advance!
Alex
Ok,
After much messing around I found the solution:
    tvp->map[4] = (char *)lightName.c_str();
Thanks for the help!!
Hi Alex,
Glad you solved the problem. :slight_smile:
No worries…
Cheers,
Pete
FYI, in v9 I’m considering to use real buttons (not button matrix) for the tab buttons which will provide much more flexibility. (Even the opportunity to add icons).
Very nice, I look forward to it.
Hi @kisvegabor ,
Can you see here and let me know what you think please :slight_smile:
Cheers,
Pete
cc @elgerg
Maybe late.
But I can change the tabview with:
lv_tabview_rename_tab(mainTabview, pageNr, newtext);
I ended up reading this topic facing an undocumented behaviour. The tabview button disapears as the new name is an empty string.
Reading Add 'tabview' functionality? · Issue #3407 · lvgl/lvgl · GitHub did not mention this behaviour.
