ESP-IDF HTTP client is now available as part of espidf module.
This is a fully featured HTTP client provided as part of ESP-IDF, including TLS, header parsing, chunked responses, etc.
Now you can use it in Micropython.
It can be useful for interacting with REST API, or simply for fetching data from the web.
Here is a simple example that shows how to send a GET request, print HTTP headers and read the payload stream:
import espidf as esp
def event_handler(evt):
if evt.event_id == esp.HTTP_EVENT.ON_HEADER:
print("%s : %s" % (evt.header_key, evt.header_value))
return 0
conf = esp.esp_http_client_config_t()
conf.url="https://lvgl.io"
conf.register_event_handler(event_handler, None)
client = conf.init()
esp.esp_http_client_open(client, 0)
esp.esp_http_client_fetch_headers(client)
buffer = bytes(256)
while True:
bytes_read = esp.esp_http_client_read(client, buffer, len(buffer))
if bytes_read < 0: break
print(buffer[:bytes_read].decode("utf-8"), end="")
if bytes_read < len(buffer): break
esp.esp_http_client_close(client)
esp.esp_http_client_cleanup(client)
