Hello! I have an ESP-LCD DevKit and use the example from GitHub. But I have the issue that any animation that is to large or runs to fast ends up in ‘tearing-up’ the graphics.
Is there anything I have missed? I found some topics about tearing, but it didn’t make me anything wiser. I can also be that the hardware is just not ‘good enough’.
The ESP-LCD DevKit with its compiler (ran from idf.py) + build in LCD screen (480*800/16bit)
I want to run some ‘smooth-ish’ animations. Like a simple square that slides in. I have tried to animate the container its width and position. When I add more content in the container itself, the lagging is more noticable.
Even tried the lv_objmask
object. Where the container that has to be shown is hidden and the mask size is animated. The idea behind this is that I thought that only updated pixels are rendered and send to the display. But with this method all pixels are send, even those that were not updated (bug?). Does anyone know more about this?
- Increase display buffer, but the S2 has not enough space for a full screen buffer
- Two ‘not full size buffers’
- Reduced code to make is as minimal as possible
- Tried different methods for animation, like updating the size, position, mask.
lv_style_init(&style_box_card);
lv_style_set_border_width(&style_box_card, LV_STATE_DEFAULT, 0);
lv_style_set_bg_color(&style_box_card, LV_STATE_DEFAULT, HW_COLOR_CURIOUS_BLUE);
lv_obj_t *cont_obj = lv_cont_create(parent, NULL);
lv_obj_set_size(cont_obj, 800, 480);
lv_obj_align(cont_obj, NULL, LV_ALIGN_IN_TOP_LEFT, 0, 0);
lv_obj_add_style(cont_obj, LV_CONT_PART_MAIN, &style_box_card);
lv_anim_init(&anim_1);
lv_anim_set_exec_cb(&anim_1, (lv_anim_exec_xcb_t) lv_obj_set_height);
lv_anim_set_var(&anim_1, cont_obj1);
lv_anim_set_time(&anim_1, 2000);
lv_anim_set_delay(&anim_1, 500);
lv_anim_set_values(&anim_1, 0, 460);
lv_anim_start(&anim_1);
Slow motion recording of the animation:
