Im trying now since a while to get a simple animation running, most basic widgets, grids, layout, styles etc seem to work well and Im slowly getting the hang of it. Unfortuantely im stuck at creating a simple animation.
Im using the sample file from the T-Display-S3-main package as a template
(T-Display-S3-main\T-Display-S3-main\examples\lv_demos)
MCU / Compiler
ESP32 S3 “Lilygo T-Display-S3” but without Touch
Arduino IDE 2.3.2
And since Lilygo is a bit tricky, im using this package: (or, need to use this package)
Which contains lvgl 8.3
Get a simple animation running (Bar, etc,…)
Currently, it shows the bar, but no animation.
I couldnt find a corresponding setting in lv_conf.h that might have disabled it.
#include <Arduino.h>
#if ESP_IDF_VERSION >= ESP_IDF_VERSION_VAL(5,0,0)
#error "The current version is not supported for the time being, please use a version below Arduino ESP32 3.0"
//Info: Resolution Lilygo TS3 (ESP32S3 Dev Module): 170x320
/* Please make sure your touch IC model. */
// #define TOUCH_MODULES_CST_MUTUAL
// #define TOUCH_MODULES_CST_SELF
#if defined(TOUCH_MODULES_CST_SELF) || defined(TOUCH_MODULES_CST_SELF)
#include "TouchLib.h"
// #define TOUCH_READ_FROM_INTERRNUPT
/* The product now has two screens, and the initialization code needs a small change in the new version. The LCD_MODULE_CMD_1 is used to define the
* switch macro. */
#define LCD_MODULE_CMD_1
#include "lv_conf.h"
#include "lvgl.h" /* https://github.com/lvgl/lvgl.git */
#include "Arduino.h"
#include "Wire.h"
#include "esp_lcd_panel_io.h"
#include "esp_lcd_panel_ops.h"
#include "esp_lcd_panel_vendor.h"
#include "pin_config.h"
#include "lv_demo_widgets.h"
void set_bar_val(void *bar, int32_t val)
lv_bar_set_value((lv_obj_t *)bar, val, LV_ANIM_ON);
void barexample(void)
//Bar Demo
lv_obj_t * bar = lv_bar_create(lv_scr_act());
lv_obj_set_size(bar, 200, 20);
lv_bar_set_value(bar, 50, LV_ANIM_ON);
lv_obj_center(bar);
//Animation
lv_anim_t animation;
lv_anim_init(&animation);
lv_anim_set_exec_cb(&animation, set_bar_val);
lv_anim_set_time(&animation, 300);
lv_anim_set_playback_time(&animation, 300);
//Connect anim to bar
lv_anim_set_var(&animation, bar);
//Start and End values
lv_anim_set_values(&animation, 0, 100);
lv_anim_set_repeat_count(&animation, LV_ANIM_REPEAT_INFINITE);
lv_anim_start(&animation);
esp_lcd_panel_io_handle_t io_handle = NULL;
static lv_disp_draw_buf_t disp_buf; // contains internal graphic buffer(s) called draw buffer(s)
static lv_disp_drv_t disp_drv; // contains callback functions
static lv_color_t *lv_disp_buf;
static bool is_initialized_lvgl = false;
#if defined(LCD_MODULE_CMD_1)
typedef struct {
uint8_t cmd;
uint8_t data[14];
uint8_t len;
} lcd_cmd_t;
lcd_cmd_t lcd_st7789v[] = {
{0x11, {0}, 0 | 0x80},
{0x3A, {0X05}, 1},
{0xB2, {0X0B, 0X0B, 0X00, 0X33, 0X33}, 5},
{0xB7, {0X75}, 1},
{0xBB, {0X28}, 1},
{0xC0, {0X2C}, 1},
{0xC2, {0X01}, 1},
{0xC3, {0X1F}, 1},
{0xC6, {0X13}, 1},
{0xD0, {0XA7}, 1},
{0xD0, {0XA4, 0XA1}, 2},
{0xD6, {0XA1}, 1},
{0xE0, {0XF0, 0X05, 0X0A, 0X06, 0X06, 0X03, 0X2B, 0X32, 0X43, 0X36, 0X11, 0X10, 0X2B, 0X32}, 14},
{0xE1, {0XF0, 0X08, 0X0C, 0X0B, 0X09, 0X24, 0X2B, 0X22, 0X43, 0X38, 0X15, 0X16, 0X2F, 0X37}, 14},
TouchLib touch(Wire, PIN_IIC_SDA, PIN_IIC_SCL, CTS328_SLAVE_ADDRESS, PIN_TOUCH_RES);
bool inited_touch = false;
#if defined(TOUCH_READ_FROM_INTERRNUPT)
bool get_int_signal = false;
static bool example_notify_lvgl_flush_ready(esp_lcd_panel_io_handle_t panel_io, esp_lcd_panel_io_event_data_t *edata, void *user_ctx)
if (is_initialized_lvgl) {
lv_disp_drv_t *disp_driver = (lv_disp_drv_t *)user_ctx;
lv_disp_flush_ready(disp_driver);
return false;
static void example_lvgl_flush_cb(lv_disp_drv_t *drv, const lv_area_t *area, lv_color_t *color_map)
esp_lcd_panel_handle_t panel_handle = (esp_lcd_panel_handle_t)drv->user_data;
int offsetx1 = area->x1;
int offsetx2 = area->x2;
int offsety1 = area->y1;
int offsety2 = area->y2;
// copy a buffer's content to a specific area of the display
esp_lcd_panel_draw_bitmap(panel_handle, offsetx1, offsety1, offsetx2 + 1, offsety2 + 1, color_map);
static void lv_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
if (get_int_signal) {
touch.read();
#else
if (touch.read()) {
TP_Point t = touch.getPoint(0);
data->point.x = t.x;
data->point.y = t.y;
} else
void setup()
Serial.begin(115200);
//Turn on display power
pinMode(PIN_POWER_ON, OUTPUT);
digitalWrite(PIN_POWER_ON, HIGH);
pinMode(PIN_LCD_RD, OUTPUT);
digitalWrite(PIN_LCD_RD, HIGH);
esp_lcd_i80_bus_handle_t i80_bus = NULL;
esp_lcd_i80_bus_config_t bus_config = {
.dc_gpio_num = PIN_LCD_DC,
.wr_gpio_num = PIN_LCD_WR,
.clk_src = LCD_CLK_SRC_PLL160M,
.data_gpio_nums =
PIN_LCD_D0,
PIN_LCD_D1,
PIN_LCD_D2,
PIN_LCD_D3,
PIN_LCD_D4,
PIN_LCD_D5,
PIN_LCD_D6,
PIN_LCD_D7,
.bus_width = 8,
.max_transfer_bytes = LVGL_LCD_BUF_SIZE * sizeof(uint16_t),
esp_lcd_new_i80_bus(&bus_config, &i80_bus);
esp_lcd_panel_io_i80_config_t io_config = {
.cs_gpio_num = PIN_LCD_CS,
.pclk_hz = EXAMPLE_LCD_PIXEL_CLOCK_HZ,
.trans_queue_depth = 20,
.on_color_trans_done = example_notify_lvgl_flush_ready,
.user_ctx = &disp_drv,
.lcd_cmd_bits = 8,
.lcd_param_bits = 8,
.dc_levels =
.dc_idle_level = 0,
.dc_cmd_level = 0,
.dc_dummy_level = 0,
.dc_data_level = 1,
ESP_ERROR_CHECK(esp_lcd_new_panel_io_i80(i80_bus, &io_config, &io_handle));
esp_lcd_panel_handle_t panel_handle = NULL;
esp_lcd_panel_dev_config_t panel_config = {
.reset_gpio_num = PIN_LCD_RES,
.color_space = ESP_LCD_COLOR_SPACE_RGB,
.bits_per_pixel = 16,
esp_lcd_new_panel_st7789(io_handle, &panel_config, &panel_handle);
esp_lcd_panel_reset(panel_handle);
esp_lcd_panel_init(panel_handle);
esp_lcd_panel_invert_color(panel_handle, true);
esp_lcd_panel_swap_xy(panel_handle, true);
esp_lcd_panel_mirror(panel_handle, false, true);
// the gap is LCD panel specific, even panels with the same driver IC, can
// have different gap value
esp_lcd_panel_set_gap(panel_handle, 0, 35);
for (uint8_t i = 0; i < (sizeof(lcd_st7789v) / sizeof(lcd_cmd_t)); i++) {
esp_lcd_panel_io_tx_param(io_handle, lcd_st7789v[i].cmd, lcd_st7789v[i].data, lcd_st7789v[i].len & 0x7f);
if (lcd_st7789v[i].len & 0x80)
delay(120);
/* Lighten the screen with gradient */
ledcSetup(0, 10000, 8);
ledcAttachPin(PIN_LCD_BL, 0);
for (uint8_t i = 0; i < 0xFF; i++) {
ledcWrite(0, i);
delay(2);
lv_disp_buf = (lv_color_t *)heap_caps_malloc(LVGL_LCD_BUF_SIZE * sizeof(lv_color_t), MALLOC_CAP_DMA | MALLOC_CAP_INTERNAL);
lv_disp_draw_buf_init(&disp_buf, lv_disp_buf, NULL, LVGL_LCD_BUF_SIZE);
/*Initialize the display*/
lv_disp_drv_init(&disp_drv);
/*Change the following line to your display resolution*/
disp_drv.hor_res = EXAMPLE_LCD_H_RES;
disp_drv.ver_res = EXAMPLE_LCD_V_RES;
disp_drv.flush_cb = example_lvgl_flush_cb;
disp_drv.user_data = panel_handle;
/* Register touch brush with LVGL */
Wire.begin(PIN_IIC_SDA, PIN_IIC_SCL, 800000);
inited_touch = touch.init();
if (inited_touch) {
touch.setRotation(1);
indev_drv.read_cb = lv_touchpad_read;
is_initialized_lvgl = true;
attachInterrupt(
PIN_TOUCH_INT, [] { get_int_signal = true; }, FALLING);
barexample();
void loop()
lv_timer_handler();
delay(5);
