Here is the current state of the code being used:
* Copyright (c) 2023 The ZMK Contributors
* SPDX-License-Identifier: MIT
#include <zephyr/kernel.h>
#include <zephyr/bluetooth/services/bas.h>
#include <zephyr/random/rand32.h>
#include <zmk/display.h>
#include "peripheral_status.h"
#include <zmk/events/usb_conn_state_changed.h>
#include <zmk/event_manager.h>
#include <zmk/events/battery_state_changed.h>
#include <zmk/split/bluetooth/peripheral.h>
#include <zmk/events/split_peripheral_status_changed.h>
#include <zmk/usb.h>
#include <zmk/ble.h>
struct Animation {
const int frameCount;
const int timeGap;
const int repetition;
const void *images[];
LV_IMG_DECLARE(kronii_001)
LV_IMG_DECLARE(kronii_002)
LV_IMG_DECLARE(kronii_003)
LV_IMG_DECLARE(kronii_004)
LV_IMG_DECLARE(kronii_005)
LV_IMG_DECLARE(kronii_006)
LV_IMG_DECLARE(kronii_007)
LV_IMG_DECLARE(kronii_008)
LV_IMG_DECLARE(kronii_009)
LV_IMG_DECLARE(kronii_010)
LV_IMG_DECLARE(marine_001)
LV_IMG_DECLARE(marine_002)
LV_IMG_DECLARE(marine_003)
LV_IMG_DECLARE(marine_004)
LV_IMG_DECLARE(marine_005)
LV_IMG_DECLARE(marine_006)
LV_IMG_DECLARE(marine_007)
LV_IMG_DECLARE(marine_008)
LV_IMG_DECLARE(marine_009)
LV_IMG_DECLARE(marine_010)
const struct Animation kronii_anim = {.frameCount = 10,
.timeGap = 100,
.repetition = 10,
.images = {&kronii_001, &kronii_002, &kronii_003, &kronii_004,
&kronii_005, &kronii_006, &kronii_007, &kronii_008,
&kronii_009, &kronii_010}};
const struct Animation marine_anim = {.frameCount = 10,
.timeGap = 100,
.repetition = 10,
.images = {&marine_001, &marine_002, &marine_003, &marine_004,
&marine_005, &marine_006, &marine_007, &marine_008,
&marine_009, &marine_010}};
int currentAnimIdx = 0;
int animsLength = 2;
const struct Animation *anims[] = {&kronii_anim, &marine_anim};
static sys_slist_t widgets = SYS_SLIST_STATIC_INIT(&widgets);
struct peripheral_status_state {
bool connected;
static void draw_top(lv_obj_t *widget, lv_color_t cbuf[], struct status_state state) {
lv_obj_t *canvas = lv_obj_get_child(widget, 0);
lv_draw_label_dsc_t label_dsc;
init_label_dsc(&label_dsc, LVGL_FOREGROUND, &lv_font_montserrat_16, LV_TEXT_ALIGN_RIGHT);
lv_draw_rect_dsc_t rect_black_dsc;
init_rect_dsc(&rect_black_dsc, LVGL_BACKGROUND);
// Fill background
lv_canvas_draw_rect(canvas, 0, 0, DISP_WIDTH, 20, &rect_black_dsc);
// Draw battery
draw_battery(canvas, state);
// Draw output status
lv_canvas_draw_text(canvas, 0, 0, CANVAS_SIZE, &label_dsc,
state.connected ? LV_SYMBOL_WIFI : LV_SYMBOL_CLOSE);
// Rotate canvas
rotate_canvas(canvas, cbuf);
static void set_battery_status(struct zmk_widget_status *widget,
struct battery_status_state state) {
#if IS_ENABLED(CONFIG_USB_DEVICE_STACK)
widget->state.charging = state.usb_present;
#endif /* IS_ENABLED(CONFIG_USB_DEVICE_STACK) */
widget->state.battery = state.level;
draw_top(widget->obj, widget->cbuf, widget->state);
static void battery_status_update_cb(struct battery_status_state state) {
struct zmk_widget_status *widget;
SYS_SLIST_FOR_EACH_CONTAINER(&widgets, widget, node) { set_battery_status(widget, state); }
static struct battery_status_state battery_status_get_state(const zmk_event_t *eh) {
return (struct battery_status_state) {
.level = bt_bas_get_battery_level(),
.usb_present = zmk_usb_is_powered(),
ZMK_DISPLAY_WIDGET_LISTENER(widget_battery_status, struct battery_status_state,
battery_status_update_cb, battery_status_get_state)
ZMK_SUBSCRIPTION(widget_battery_status, zmk_battery_state_changed);
ZMK_SUBSCRIPTION(widget_battery_status, zmk_usb_conn_state_changed);
static struct peripheral_status_state get_state(const zmk_event_t *_eh) {
return (struct peripheral_status_state){.connected = zmk_split_bt_peripheral_is_connected()};
static void set_connection_status(struct zmk_widget_status *widget,
struct peripheral_status_state state) {
widget->state.connected = state.connected;
static void output_status_update_cb(struct peripheral_status_state state) {
SYS_SLIST_FOR_EACH_CONTAINER(&widgets, widget, node) { set_connection_status(widget, state); }
ZMK_DISPLAY_WIDGET_LISTENER(widget_peripheral_status, struct peripheral_status_state,
output_status_update_cb, get_state)
ZMK_SUBSCRIPTION(widget_peripheral_status, zmk_split_peripheral_status_changed);
const void **images;
uint8_t images_len;
struct zmk_widget_status *lastWidget;
void set_img_src(void *var, int32_t val);
void set_anim() {
// Params
int anim_len = anims[currentAnimIdx]->frameCount;
int per_frame_time_in_ms = anims[currentAnimIdx]->timeGap;
// Init animations
lv_anim_init(&lastWidget->anim);
lv_anim_set_var(&lastWidget->anim, lastWidget->obj);
lv_anim_set_time(&lastWidget->anim, anim_len * per_frame_time_in_ms);
lv_anim_set_values(&lastWidget->anim, 0, anim_len - 1);
lv_anim_set_exec_cb(&lastWidget->anim, (lv_anim_exec_xcb_t)set_img_src);
lv_anim_set_repeat_count(&lastWidget->anim, LV_ANIM_REPEAT_INFINITE);
lv_anim_set_delay(&lastWidget->anim, 0);
lv_anim_start(&lastWidget->anim);
long long int framesPlayed = 0;
void set_img_src(void *var, int32_t val) {
lv_obj_t *img = (lv_obj_t *)var;
lv_img_set_src(img, anims[currentAnimIdx]->images[val]);
if (anims[currentAnimIdx]->repetition != -1) {
framesPlayed++;
if (anims[currentAnimIdx]->repetition * anims[currentAnimIdx]->frameCount == framesPlayed) {
currentAnimIdx++;
framesPlayed = 0;
if (currentAnimIdx >= animsLength) {
currentAnimIdx = 0;
set_anim();
int zmk_widget_status_init(struct zmk_widget_status *widget, lv_obj_t *parent) {
lastWidget = widget;
widget->obj = lv_img_create(parent);
lv_obj_set_size(widget->obj, 160, DISP_WIDTH);
lv_obj_t *top = lv_canvas_create(widget->obj);
lv_obj_align(top, LV_ALIGN_TOP_RIGHT, DISP_WIDTH, 0);
lv_canvas_set_buffer(top, widget->cbuf, DISP_WIDTH, 20, LV_IMG_CF_TRUE_COLOR);
set_anim();
sys_slist_append(&widgets, &widget->node);
widget_battery_status_init();
widget_peripheral_status_init();
return 0;
lv_obj_t *zmk_widget_status_obj(struct zmk_widget_status *widget) { return widget->obj; }
All relevant files can be found here: https://github.com/jyojoh/zmk/tree/main/app/boards/shields/nice_view/widgets
The code pasted above is from peripheral_status.c
