AI Monitor: LVGL 9.6 on ESP32-P4 and experimental ESP32-S3
Hi everyone!
I’ve been working on AI Monitor, an open-source desk companion for AI coding tools, built around LVGL 9.6. The original hardware is the GUITION JC4880P433 ESP32-P4 touchscreen, and v1.13.0 adds a separately selectable, experimental Waveshare ESP32-S3-Touch-LCD-4.3 firmware.
The idea is to keep supported AI usage limits on a small dedicated screen, while an animated robot reacts to recorded token activity on the PC. It connects over USB, so the display does not need cloud credentials.
AI Monitor P4 - NOVA and ORBIT UI previews
These are renders from the actual LVGL interface using synthetic data, not photographs of the hardware.
Update: v1.16.1 — clearer usage settings and tested Windows setup
SET > AI USAGE now explains each provider directly on the display. Every window shows its remaining percentage and data status, with a separate saved selection for NOVA and ORBIT. Live values update while Settings stays open, without rebinding a touch target; REFRESH reloads available options explicitly.
  • Codex: 5 HOURS / 7 DAYS, with instructions to sign in using ChatGPT in the PC app.
  • ZCode: 5 HOURS / 7 DAYS model quotas when reported, plus the separate MONTHLY MCP tool-call quota. Add your own ZAI Coding Plan API key in the PC app. Monthly MCP is not a monthly model-token budget. The host now reads that monthly row and correctly labels the weekly model row.
  • Claude Code: optional statusline bridge for reported quota. Gemini CLI: recorded local activity only. Other editor integrations explain their numeric bridge requirements.
  • Known missing windows remain visible and selectable, but NOT REPORTED never becomes a fabricated percentage. Alerts still check every window.
Codex settings and sign-in help
ZCode model quotas and monthly MCP quota
Actual LVGL UI renders using synthetic values, not hardware photos.
The larger companion status area retains 40-pixel percentages, 20-pixel provider names and 16-pixel status text. Alerts use a 136-pixel banner, 24-pixel heading, 20-pixel quota text and a 60-pixel DISMISS target.
Windows setup: download AI-Monitor-Setup-v1.16.1-windows.exe. The per-user installer contains the Qt app, runtime, flasher and both firmware choices; no separate Python/PlatformIO installation or administrator access is required. Choose your board/providers, use your own account/key, review the USB target and confirm firmware writing in the app. Firmware progress and errors remain visible. Double-clicking the CLI helper offers to open the graphical Firmware tab. Closing the desktop app leaves the independent host running invisibly.
Validation: 148 Python tests, both firmware builds, native LVGL/protocol tests under both board profiles, NVS checks, clean Windows installation/upgrade/settings-preserving uninstall, and packaged GUI/flasher startup checks. The P4 application update and stable boot were verified on the physical board. S3 is still experimental and untested on physical S3 hardware. Windows binaries remain unsigned, so SmartScreen may warn; Windows protections are not disabled.
Download v1.16.1 — installer, portable ZIP and SHA-256 checksums
Hardware and LVGL implementation
  • GUITION JC4880P433, 4.3-inch ST7701S MIPI-DSI panel and GT911 capacitive touch.
  • 800 x 480 landscape UI, Arduino/PlatformIO and LVGL 9.6.
  • LVGL and backlight updates owned by a dedicated FreeRTOS UI task.
  • Transparent RGB565+A8 companion images, so the robots blend into different backgrounds.
  • Persistent display settings, with save feedback and validation.
New in v1.13.0: selectable ESP32-S3 firmware
The same repository and Windows package now let users explicitly choose GUITION P4 or the original Waveshare ESP32-S3-Touch-LCD-4.3 before choosing their AI providers. Each board has its own firmware image and display backend; the host checks the selected board’s identity and the flasher verifies chip headers, offsets and SHA-256.
The S3 target uses an ST7262 RGB panel, GT911 touch and the CH422G expander, with 16 MB flash and 8 MB OPI PSRAM. It uses one PSRAM framebuffer, RGB bounce buffers, a partial LVGL draw buffer and Espressif’s matching PSRAM XIP SDK. Use its USB TO UART connector for both flashing and host data. B/C variants are not supported.
S3 is experimental and has not been tested on physical hardware. Both firmware targets compile and the shared protocol/UI tests pass, but RGB stability, tearing, touch alignment and sustained operation need a real S3 board test. The original S3 backlight supports on/off only: intermediate brightness visually dims the image; only zero switches the LEDs off. P4 retains PWM dimming.
Board compatibility and S3 setup
What the UI does
You can switch between two companions, NOVA and ORBIT, and four themes: Forest, Ocean, Amethyst and Ember.
There is also a provider dashboard, detailed quota windows, reset countdowns, manual refresh, low/critical warnings, session history, brightness presets, gradual idle dimming and scheduled night brightness.
Robot activity and quota polling are separate: the robot follows increases in recorded local token counters. Some clients save usage only when a request finishes, so activity can lag generation. This is not a billing ledger or a per-token stream.
AI integrations and PC setup
Native local activity adapters cover Codex, ZCode, Claude Code and Gemini CLI. Codex and ZCode have quota integrations; Claude quota can use its documented statusline bridge. Other selectable providers require an external numeric telemetry bridge, rather than automatic tracking.
The Windows package includes the host runtime, firmware flasher and separate prebuilt firmware for both board choices. Extract it, open AI-Monitor.exe, choose your board, providers and USB port, then start the host. No board or AI is preselected on a fresh installation. Codex setup offers the official CLI installation/sign-in when needed, using the new user’s own account.
Source, UI previews and setup instructions:
Ready-to-run Windows package:
The USB protocol follows AIM1/JSON from tobymarks/esp32-ai-monitor, with project extensions for local activity and display controls. Credit to that project for the protocol reference. Project-owned code and robot artwork are MIT; bundled components and provider marks retain their own terms.
I’d appreciate feedback on the LVGL UI, the robot/theme approach, and the experience on the P4 board. Feedback from anyone testing the original Waveshare S3 board would also help. If you build one, I’d love to see your setup!
I’ve added a two-minute overview showing NOVA and ORBIT, the actual LVGL screens, saved themes and the new AI usage settings. It also explains the USB host and Windows setup. English narration, subtitles and chapters are included.
The UI previews use synthetic demo values; this is an animated overview, not camera footage of the hardware. The original Waveshare S3 target remains experimental.
A setup tip from testing with two USB boards connected: choose the display’s explicit COM port instead of auto, then save settings and start the host. Auto detection deliberately refuses to guess between matching devices. The README and Quick Start now explain this.
Source and setup: GitHub - catorendal-a11y/ai-monitor-p4-s3: LVGL AI desk companion for GUITION ESP32-P4 and experimental Waveshare ESP32-S3 4.3-inch touchscreens. NOVA/ORBIT, themes, token activity and portable Windows setup. · GitHub
Update: v1.17.2 — tested from erased P4 flash
A full uninstall-and-reinstall test found two real setup defects: the old P4 factory bootloader declared 4 MB rather than the board’s 16 MB, and Windows could select npm’s Unix Codex launcher. v1.17.2 fixes both. Do not use v1.17.0 for a new P4 installation. Existing application-only updates did not expose that bootloader defect.
The exact v1.17.2 CI installer was tested with an empty AI Monitor configuration and erased physical P4 flash. Board/providers/key/USB selection and First installation were completed through the GUI; the P4 booted without a manual repair and both Codex/ZCode quotas were received. 185 Python tests, both firmware builds, native LVGL checks and Windows install/upgrade/uninstall checks passed. Factory capacity and partition validation now run before packaging and flashing.
Windows binaries remain unsigned, so SmartScreen may warn. Microsoft’s earlier-file submission is not approval of this different installer. S3 remains experimental and physically untested; advanced bridge requirements are unchanged.
Download the corrected v1.17.2 installer and portable package
Previous update: v1.17.0 — guided AI setup and verified host health
The new Windows AI setup tab has provider checks, Codex install/sign-in and an optional Claude quota link that can be removed without replacing a custom statusline. OpenCode now reads supported local numeric usage automatically; Copilot, Cursor and Antigravity still require an advanced numeric bridge.
Host settings adds USB retry, local token polling, terminal text size and start/close preferences. Process status, verified USB identity and quota readiness are shown separately. The firmware Settings help reflects the provider changes.
176 Python tests, both firmware builds, native LVGL checks and packaged Windows installation/upgrade/uninstall checks passed. I also used the exact release installer and application update on my physical P4, preserving settings and confirming live Codex/ZCode quota readiness. S3 remains experimental and physically untested.
The installer is still unsigned. The exact file was submitted to Microsoft for review; the decision is pending and SmartScreen may still warn. No Windows protections are disabled.
Download v1.17.2: installer, portable ZIP and SHA-256 checksums
