Adjusting label text selection rectangle size
I am not able to change the height of the selection rectangle of Label text.
ILI9341, gcc
8.3
I am dynamically selecting different parts of the label text by changing selection start and end index. I am also able to change the selection color. But I am unable to change the selection rectangle size. The selection rectangle just cover the text, I want this selection rectangle taller than the text and text appear in the middle. How to do this ?
By adjusting line space using lv_style_set_text_line_space() I am able to extend the bottom of the selection rectangle lower than the text bottom, but then the top edge of the selection rectangle still touch the text. I need similar spacing above the text as well.
