Hi all!
I’m building a radio with lcd. For interface I’d like to use LVGL.
I’ve generated the makefile for STM32F103C8T6 via Stm32CubeIde, now I’d like to add LVGL to the project.
I’ve cloned the library, according to the porting gyde, added the next lines to the almost top of my makefile:
LVGL_DIR_NAME ?= lvgl #The name of the lvgl folder (change this if you have renamed it)
LVGL_DIR ?= ${shell pwd} #The path where the lvgl folder is
include $(LVGL_DIR)/$(LVGL_DIR_NAME)/lvgl.mk
To the main file I’ve added lv_init() and lv_tick_inc() functions, but unfortunately I’ve met the next error while trying to build:
/opt/gcc-arm-none-eabi-10-2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld: build/main.o: in function `main':
/mnt/d/Work/radiodevice/Src/main.c:29: undefined reference to `lv_init'
/opt/gcc-arm-none-eabi-10-2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld: /mnt/d/Work/radiodevice/Src/main.c:33: undefined reference to `lv_tick_inc'
collect2: error: ld returned 1 exit status
make: *** [Makefile:131: build/radiodevice.elf] Error 1
Does anyone tried to add LVGL to the makefile and tried to build it? Maybe, any workaround?
Could anyone help with advise, or etc.?
STM32F103C8T6
arm-none-eabi-gcc (GNU Arm Embedded Toolchain 10-2020-q4-major) 10.2.1 20201103 (release)
Copyright (C) 2020 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Successfully ported LVGL to my project.
I’ve tried to look forum for similar answers,
direct building of lvgl and then adding it to project (no success for stm, but seems like work-able workaround for Linux.),
Tried to find similar projects on Github (but no makefile projects found
My project has the next structure:
/Drivers - HAL and CMSIS folder;
/Inc - Headers;
/Src - Source files;
/lvgl - lvgl library, checked branches v8.3 and master;
/lv_conf.h;
/Makefile.
My main.c:
#include "main.h"
#include "stm32f1xx_hal.h"
#include "i2c.h"
#include "spi.h"
#include "gpio.h"
#include "gc9a01.h"
#include "lvgl.h"
int _write(int file, char *ptr, int len)
/* Implement your write code here, this is used by puts and printf for example */
int i=0;
for(i=0 ; i<len ; i++)
ITM_SendChar((*ptr++));
return len;
//void SystemClock_Config(void);
int main(void)
HAL_Init();
SystemClock_Config();
//GPIO_Init();
//I2C2_Init();
// SPI1_Init();
//GC9A01_Init();
while (1)
HAL_Delay(10);
lv_tick_inc(10);
My makefile:
TARGET = radiodevice
DEBUG = 1
OPT = -Og
# Build path
BUILD_DIR = build
# C sources
C_SOURCES = \
Src/main.c \
Src/stm32f1xx_it.c \
Src/stm32f1xx_hal_msp.c \
Src/system_stm32f1xx.c \
Src/gpio.c \
Src/i2c.c \
Src/spi.c \
Src/gc9a01.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_gpio_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_i2c.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_rcc.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_rcc_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_gpio.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_dma.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_cortex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_pwr.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_flash.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_flash_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_exti.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_spi.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_tim.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_tim_ex.c
# ASM sources
ASM_SOURCES = \
startup_stm32f103xb.s
# binaries
PREFIX = arm-none-eabi-
# The gcc compiler bin path can be either defined in make command via GCC_PATH variable (> make GCC_PATH=xxx)
# either it can be added to the PATH environment variable.
ifdef GCC_PATH
CC = $(GCC_PATH)/$(PREFIX)gcc
AS = $(GCC_PATH)/$(PREFIX)gcc -x assembler-with-cpp
CP = $(GCC_PATH)/$(PREFIX)objcopy
SZ = $(GCC_PATH)/$(PREFIX)size
CC = $(PREFIX)gcc
AS = $(PREFIX)gcc -x assembler-with-cpp
CP = $(PREFIX)objcopy
SZ = $(PREFIX)size
endif
HEX = $(CP) -O ihex
BIN = $(CP) -O binary -S
# CFLAGS
# cpu
CPU = -mcpu=cortex-m3
MCU = $(CPU) -mthumb $(FPU) $(FLOAT-ABI)
# C defines
C_DEFS = \
-DUSE_HAL_DRIVER \
-DSTM32F103xB
# C includes
C_INCLUDES = \
-IInc \
-Ilvgl \
-IDrivers/STM32F1xx_HAL_Driver/Inc \
-IDrivers/STM32F1xx_HAL_Driver/Inc/Legacy \
-IDrivers/CMSIS/Device/ST/STM32F1xx/Include \
-IDrivers/CMSIS/Include
# compile gcc flags
ASFLAGS = $(MCU) $(AS_DEFS) $(AS_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
CFLAGS += $(MCU) $(C_DEFS) $(C_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
ifeq ($(DEBUG), 1)
CFLAGS += -g -gdwarf-2
endif
# Generate dependency information
CFLAGS += -MMD -MP -MF"$(@:%.o=%.d)"
# link script
LDSCRIPT = STM32F103C8Tx_FLASH.ld
# libraries
LIBS = -lc -lm -lnosys
LIBDIR =
LDFLAGS = $(MCU) -specs=nano.specs -T$(LDSCRIPT) $(LIBDIR) $(LIBS) -Wl,-Map=$(BUILD_DIR)/$(TARGET).map,--cref -Wl,--gc-sections
# default action: build all
all: $(BUILD_DIR)/$(TARGET).elf $(BUILD_DIR)/$(TARGET).hex $(BUILD_DIR)/$(TARGET).bin
# build the application
# list of objects
OBJECTS = $(addprefix $(BUILD_DIR)/,$(notdir $(C_SOURCES:.c=.o)))
LVGL_OBS=$(CSRCS:.c=.o)
vpath %.c $(sort $(dir $(C_SOURCES)))
# list of ASM program objects
OBJECTS += $(addprefix $(BUILD_DIR)/,$(notdir $(ASM_SOURCES:.s=.o)))
vpath %.s $(sort $(dir $(ASM_SOURCES)))
$(BUILD_DIR)/%.o: %.c Makefile | $(BUILD_DIR)
$(CC) -c $(CFLAGS) -Wa,-a,-ad,-alms=$(BUILD_DIR)/$(notdir $(<:.c=.lst)) $< -o $@
$(BUILD_DIR)/%.o: %.s Makefile | $(BUILD_DIR)
$(AS) -c $(CFLAGS) $< -o $@
$(BUILD_DIR)/$(TARGET).elf: $(OBJECTS) Makefile
$(CC) $(OBJECTS) $(LDFLAGS) -o $@
$(SZ) $@
$(BUILD_DIR)/%.hex: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
$(HEX) $< $@
$(BUILD_DIR)/%.bin: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
$(BIN) $< $@
$(BUILD_DIR):
mkdir $@
clean:
-rm -fR $(BUILD_DIR)
-include $(wildcard $(BUILD_DIR)/*.d)
