Adding custom image, can't find LV_COLOR_FORMAT_RGB565 and LV_HEADER_MAGIC
I’ve generated a .c file with the image converter from lvgl and added the file to my code. I then wanted to use it with first declaring it with
LV_IMG_DECLARE(coffee_symbol);
but the compiler gave me the errors:
C:/Users/Noe Steiner/Documents/VSCODE_Software/LaDoria_Display/main/coffee_symbol.c:70:16: error: 'LV_COLOR_FORMAT_RGB565' undeclared here (not in a function)
   70 |   .header.cf = LV_COLOR_FORMAT_RGB565,
C:/Users/Noe Steiner/Documents/VSCODE_Software/LaDoria_Display/main/coffee_symbol.c:71:11: error: 'lv_img_header_t' has no member named 'magic'
   71 |   .header.magic = LV_IMAGE_HEADER_MAGIC,
C:/Users/Noe Steiner/Documents/VSCODE_Software/LaDoria_Display/main/coffee_symbol.c:71:19: error: 'LV_IMAGE_HEADER_MAGIC' undeclared here (not in a function)
ESP32-S3, ESP-IDF extension in VS Code
9.0
Import a image generated with the image converter
const lv_img_dsc_t coffee_symbol = {
  .header.w = 50,
  .header.h = 50,
  .data_size = 2500 * 2,
  .data = coffee_symbol_map,
Could you check the latest LVGL version and report if you’re still having this issue?
