If a LV_INDEV_TYPE_KEYPAD driver is added before a LV_INDEV_TYPE_POINTER, then later on when adding a button matrix object to an object group, the program crashes.
Nintendo Switch Howebew system module using libnx, compiled with DevkitA64. Crash also reproduced on lv_sim_visual_studio_sdl
What do you experience?
I registered a LV_INDEV_TYPE_KEYPAD driver then registered a LV_INDEV_TYPE_POINTER.
Later on, when I tried to add a button matrix object to an object group, the program crashes.
What do you expect?
I expect it not to crash simply because of the order of registering my input devices. When I switched the order of the 2 driver initialization, no crash occurred.
A code snippet to reproduce the issue in the lv_sim_visual_studio_sdl simulator.
lv_obj_t* p_buttonMatrix = lv_btnm_create(lv_scr_act(), NULL);
lv_btnm_set_map(p_buttonMatrix, SOME_BUTTON_MAP_LAYOUT);
lv_group_t* p_objGroup = lv_group_create();
lv_group_add_obj(p_objGroup, p_buttonMatrix); // <--- code crashes here
lv_indev_set_group(kb_indev, p_objGroup);
This order will cause the crash:
/* If the PC keyboard driver is enabled in`lv_drv_conf.h`
* add this as an input device. It might be used in some examples. */
#if USE_KEYBOARD
lv_indev_drv_t kb_drv;
lv_indev_drv_init(&kb_drv);
kb_drv.type = LV_INDEV_TYPE_KEYPAD;
kb_drv.read_cb = keyboard_read;
kb_indev = lv_indev_drv_register(&kb_drv);
/* Add the mouse (or touchpad) as input device
* Use the 'mouse' driver which reads the PC's mouse*/
mouse_init();
lv_indev_drv_t indev_drv;
lv_indev_drv_init(&indev_drv); /*Basic initialization*/
indev_drv.read_cb =
mouse_read; /*This function will be called periodically (by the library) to get the mouse position and state*/
This order runs fine:
mouse_init();
indev_drv.read_cb =
#if USE_KEYBOARD
