ESP32s3 Dev Module
8.3.3
Add custom heart icon to button (Only “[]” is displayed)
Add custom font including icon with Online font converter.
Add icon to lv_symbol_def.h
Move font into lvgl/src/font
workingScreen.ino
ESP32 | LVGL8 | Ep 0. GFX Setup (ft. LovyanGFX)
Video Tutorial: https://youtu.be/IPCvQ4o_WP8
Created by Eric N. (ThatProject)
#define LGFX_USE_V1
#define MY_SEARCH_SYMBOL "\xEF\x8F\xBD"
#include <LovyanGFX.hpp>
#include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp>
#include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp>
#include <driver/i2c.h>
#include <lvgl.h>
#include <lv_conf_internal.h>
#include <myFont.c>
class LGFX : public lgfx::LGFX_Device {
public:
lgfx::Bus_RGB _bus_instance;
lgfx::Panel_RGB _panel_instance;
lgfx::Light_PWM _light_instance;
lgfx::Touch_GT911 _touch_instance;
LGFX(void) {
auto cfg = _panel_instance.config();
cfg.memory_width = 800;
cfg.memory_height = 480;
cfg.panel_width = 800;
cfg.panel_height = 480;
cfg.offset_x = 0;
cfg.offset_y = 0;
_panel_instance.config(cfg);
auto cfg = _bus_instance.config();
cfg.panel = &_panel_instance;
cfg.pin_d0 = GPIO_NUM_15; // B0
cfg.pin_d1 = GPIO_NUM_7; // B1
cfg.pin_d2 = GPIO_NUM_6; // B2
cfg.pin_d3 = GPIO_NUM_5; // B3
cfg.pin_d4 = GPIO_NUM_4; // B4
cfg.pin_d5 = GPIO_NUM_9; // G0
cfg.pin_d6 = GPIO_NUM_46; // G1
cfg.pin_d7 = GPIO_NUM_3; // G2
cfg.pin_d8 = GPIO_NUM_8; // G3
cfg.pin_d9 = GPIO_NUM_16; // G4
cfg.pin_d10 = GPIO_NUM_1; // G5
cfg.pin_d11 = GPIO_NUM_14; // R0
cfg.pin_d12 = GPIO_NUM_21; // R1
cfg.pin_d13 = GPIO_NUM_47; // R2
cfg.pin_d14 = GPIO_NUM_48; // R3
cfg.pin_d15 = GPIO_NUM_45; // R4
cfg.pin_henable = GPIO_NUM_41;
cfg.pin_vsync = GPIO_NUM_40;
cfg.pin_hsync = GPIO_NUM_39;
cfg.pin_pclk = GPIO_NUM_0;
cfg.freq_write = 12000000;
cfg.hsync_polarity = 0;
cfg.hsync_front_porch = 40;
cfg.hsync_pulse_width = 48;
cfg.hsync_back_porch = 40;
cfg.vsync_polarity = 0;
cfg.vsync_front_porch = 1;
cfg.vsync_pulse_width = 31;
cfg.vsync_back_porch = 13;
cfg.pclk_active_neg = 1;
cfg.de_idle_high = 0;
cfg.pclk_idle_high = 0;
_bus_instance.config(cfg);
_panel_instance.setBus(&_bus_instance);
auto cfg = _light_instance.config();
cfg.pin_bl = GPIO_NUM_2;
_light_instance.config(cfg);
_panel_instance.light(&_light_instance);
auto cfg = _touch_instance.config();
cfg.x_min = 0;
cfg.x_max = 799;
cfg.y_min = 0;
cfg.y_max = 479;
cfg.pin_int = -1;
cfg.pin_rst = -1;
cfg.bus_shared = false;
cfg.offset_rotation = 0;
cfg.i2c_port = I2C_NUM_1;
cfg.pin_sda = GPIO_NUM_19;
cfg.pin_scl = GPIO_NUM_20;
cfg.freq = 400000;
cfg.i2c_addr = 0x14;
_touch_instance.config(cfg);
_panel_instance.setTouch(&_touch_instance);
setPanel(&_panel_instance);
LGFX lcd;
/*Change to your screen resolution*/
static const uint32_t screenWidth = 800;
static const uint32_t screenHeight = 480;
static lv_color_t buf[ screenWidth * 10 ];
static const char * const keyboard_small_chars[] = {"1#", "q", "w", "e", "r", "t", "y", "u", "i", "o", "p", LV_SYMBOL_BACKSPACE, "\n",
"ABC", "a", "s", "d", "f", "g", "h", "j", "k", "l", LV_SYMBOL_NEW_LINE, "\n",
"_", "-", "z", "x", "c", "v", "b", "n", "m", ".", ",", ":", "\n",
LV_SYMBOL_CLOSE,LV_SYMBOL_LEFT, " ", LV_SYMBOL_RIGHT, LV_SYMBOL_OK, ""};
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
lcd.startWrite();
lcd.setAddrWindow( area->x1, area->y1, w, h );
//lcd.pushColors( ( uint16_t * )&color_p->full, w * h, true );
lcd.writePixels((lgfx::rgb565_t *)&color_p->full, w * h);
lcd.endWrite();
lv_disp_flush_ready( disp );
/*Read the touchpad*/
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data )
uint16_t touchX, touchY;
bool touched = lcd.getTouch( &touchX, &touchY);
if( !touched )
/*Set the coordinates*/
data->point.x = touchX;
data->point.y = touchY;
Serial.print( "Data x " );
Serial.println( touchX );
Serial.print( "Data y " );
Serial.println( touchY );
void setup()
Serial.begin(115200);
lcd.init();
lcd.setBrightness(255);
uint16_t calData[] = { 239, 3926, 233, 265, 3856, 3896, 3714, 308};
lcd.setTouchCalibrate(calData);
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * 10 );
/*Initialize the display*/
lv_disp_drv_init(&disp_drv);
/*Change the following line to your display resolution*/
lv_example_get_started_1();
delay(100);
hug();
void loop()
delay( 5 );
static void ta_event_cb(lv_event_t * e)
lv_obj_t * ta = (lv_obj_t*) lv_event_get_target(e);
lv_obj_t * kb = (lv_obj_t*) lv_event_get_user_data(e);
Serial.println( code );
if(code == LV_EVENT_FOCUSED) {
lv_keyboard_set_textarea(kb, ta);
if(code == LV_EVENT_DEFOCUSED) {
lv_keyboard_set_textarea(kb, NULL);
static void btn_event_cb(lv_event_t * e)
lv_obj_t * btn = lv_event_get_target(e);
Serial.print('clicked');
static uint8_t cnt = 0;
cnt++;
/*Get the first child of the button which is the label and change its text*/
lv_obj_t * label = lv_obj_get_child(btn, 0);
lv_label_set_text_fmt(label, "Button: %d", cnt);
* Create a button with a label and react on click event.
void lv_example_get_started_1(void)
lv_obj_create(NULL);
/*Create a text area. The keyboard will write here*/
lv_obj_t * kb = lv_keyboard_create(lv_scr_act());
lv_obj_t * ta1;
ta1 = lv_textarea_create(lv_scr_act());
lv_obj_align(ta1, LV_ALIGN_TOP_MID, 0, 40);
lv_obj_add_event_cb(ta1, ta_event_cb, LV_EVENT_ALL, kb);
lv_textarea_set_placeholder_text(ta1, "Hello");
lv_obj_set_size(ta1, 140, 80);
lv_keyboard_set_textarea(kb, ta1);
lv_textarea_add_text(ta1, "Servus/nServus");
lv_obj_t * btn2 = lv_btn_create(lv_scr_act());
lv_obj_add_event_cb(btn2, btn_event_cb, LV_EVENT_ALL, NULL);
lv_obj_align(btn2, LV_ALIGN_CENTER, 0, -40);
lv_obj_t * label = lv_label_create(btn2);
static lv_style_t style;
lv_style_init(&style);
lv_style_set_text_font(&style, &myFont); // <--- you have to enable other font sizes in menuconfig
lv_obj_add_style(label, &style, LV_PART_MAIN); // <--- obj is the label
lv_label_set_text(label, HEART_SYMBOL);
//lv_label_set_text(label, "test");
lv_obj_center(label);
void hug() {
delay(40);
addition to lv_symbol_def.h
#define HEART_SYMBOL "\xEF\x96\x96"
addition to lv_symbol_def.h enums
_LV_STR_SYMBOL_HEART
myFont.c
* Size: 12 px
* Bpp: 1
* Opts:
#include "lvgl.h"
#ifndef MYFONT
#define MYFONT 1
#if MYFONT
* BITMAPS
/*Store the image of the glyphs*/
static LV_ATTRIBUTE_LARGE_CONST const uint8_t glyph_bitmap[] = {
/* U+0020 " " */
0x0,
/* U+002D "-" */
0xe0,
/* U+002E "." */
0x80,
/* U+0030 "0" */
0x79, 0x28, 0x61, 0x86, 0x18, 0x61, 0x49, 0xe0,
/* U+0031 "1" */
0x23, 0x28, 0x42, 0x10, 0x84, 0x27, 0xc0,
/* U+0032 "2" */
0x74, 0x42, 0x11, 0x88, 0x88, 0xc7, 0xc0,
/* U+0033 "3" */
0x39, 0x10, 0x41, 0xc, 0xe0, 0x41, 0x5, 0xe0,
/* U+0034 "4" */
0x8, 0x61, 0x8a, 0x29, 0x28, 0xbf, 0x8, 0x20,
/* U+0035 "5" */
0xfc, 0x21, 0xf, 0x4c, 0x21, 0x9b, 0x80,
/* U+0036 "6" */
0x39, 0x18, 0x20, 0xbb, 0x38, 0x61, 0x4c, 0xe0,
/* U+0037 "7" */
0xfc, 0x10, 0x82, 0x10, 0x43, 0x8, 0x21, 0x0,
/* U+0038 "8" */
0x7a, 0x18, 0x61, 0x79, 0xe8, 0x61, 0x85, 0xe0,
/* U+0039 "9" */
0x73, 0x28, 0x61, 0x87, 0x37, 0x41, 0x89, 0xc0,
/* U+0041 "A" */
0x8, 0xc, 0x5, 0x2, 0x82, 0x61, 0x10, 0x88,
0xfe, 0x41, 0x40, 0x80,
/* U+0042 "B" */
0xfa, 0x18, 0x61, 0x87, 0xe8, 0x61, 0x87, 0xe0,
/* U+0043 "C" */
0x3c, 0x86, 0x4, 0x8, 0x10, 0x20, 0x40, 0x42,
0x78,
/* U+0044 "D" */
0xf9, 0xa, 0x1c, 0x18, 0x30, 0x60, 0xc3, 0x85,
0xf0,
/* U+0045 "E" */
0xfc, 0x21, 0x8, 0x7e, 0x10, 0x87, 0xc0,
/* U+0046 "F" */
0xfc, 0x21, 0x8, 0x7e, 0x10, 0x84, 0x0,
/* U+0047 "G" */
0x3c, 0x86, 0x4, 0x8, 0x11, 0xe0, 0xc1, 0x42,
0x7c,
/* U+0048 "H" */
0x83, 0x6, 0xc, 0x18, 0x3f, 0xe0, 0xc1, 0x83,
0x4,
/* U+0049 "I" */
0xff, 0xc0,
/* U+004A "J" */
0x24, 0x92, 0x49, 0x24, 0xe0,
/* U+004B "K" */
0x85, 0x12, 0x45, 0xc, 0x1c, 0x2c, 0x48, 0x89,
0x8,
/* U+004C "L" */
0x84, 0x21, 0x8, 0x42, 0x10, 0x87, 0xc0,
/* U+004D "M" */
0x81, 0x81, 0xc3, 0xc3, 0xa5, 0xa5, 0xa5, 0x99,
0x99, 0x99,
/* U+004E "N" */
0x83, 0x87, 0xd, 0x19, 0x32, 0x62, 0xc3, 0x87,
0x4,
/* U+004F "O" */
0x3c, 0x42, 0xc3, 0x81, 0x81, 0x81, 0x81, 0xc3,
0x42, 0x3c,
/* U+0050 "P" */
0xfa, 0x18, 0x61, 0x87, 0xe8, 0x20, 0x82, 0x0,
/* U+0051 "Q" */
0x42, 0x3c, 0x4, 0x2,
/* U+0052 "R" */
0xfa, 0x18, 0x61, 0x87, 0xe8, 0xa1, 0x86, 0x10,
/* U+0053 "S" */
0x7b, 0x18, 0x20, 0x60, 0xe0, 0x41, 0x8d, 0xe0,
/* U+0054 "T" */
0xfe, 0x20, 0x40, 0x81, 0x2, 0x4, 0x8, 0x10,
0x20,
/* U+0055 "U" */
0x83, 0x6, 0xc, 0x18, 0x30, 0x60, 0xc1, 0x44,
0xf8,
/* U+0056 "V" */
0x81, 0x41, 0x42, 0x42, 0x22, 0x24, 0x24, 0x14,
0x18, 0x8,
/* U+0057 "W" */
0x42, 0xa, 0x18, 0x91, 0x44, 0x8a, 0x22, 0x51,
0x12, 0x50, 0xa2, 0x83, 0x14, 0x18, 0x40, 0x82,
0x0,
/* U+0058 "X" */
0x42, 0x46, 0x24, 0x38, 0x18, 0x18, 0x2c, 0x24,
0x42, 0xc2,
/* U+0059 "Y" */
0x83, 0x8d, 0x11, 0x43, 0x82, 0x4, 0x8, 0x10,
0x20,
/* U+005A "Z" */
0xfc, 0x10, 0x84, 0x10, 0x82, 0x10, 0x83, 0xf0,
/* U+0061 "a" */
0x77, 0x38, 0x61, 0x87, 0x37, 0x40,
/* U+0062 "b" */
0x82, 0x8, 0x2e, 0xce, 0x18, 0x61, 0xce, 0xe0,
/* U+0063 "c" */
0x7e, 0x61, 0x8, 0x65, 0xe0,
/* U+0064 "d" */
0x4, 0x10, 0x5d, 0xce, 0x18, 0x61, 0xcd, 0xd0,
/* U+0065 "e" */
0x73, 0x28, 0xbe, 0x83, 0x7, 0x80,
/* U+0066 "f" */
0x74, 0x4e, 0x44, 0x44, 0x44,
/* U+0067 "g" */
0x77, 0x38, 0x61, 0x87, 0x37, 0x41, 0x78,
/* U+0068 "h" */
0x84, 0x21, 0x6c, 0xc6, 0x31, 0x8c, 0x40,
/* U+0069 "i" */
0x9f, 0xc0,
/* U+006A "j" */
0x20, 0x12, 0x49, 0x24, 0xf0,
/* U+006B "k" */
0x84, 0x21, 0x39, 0x53, 0x14, 0x94, 0x40,
/* U+006C "l" */
0xff, 0xc0,
/* U+006D "m" */
0xb7, 0x66, 0x62, 0x31, 0x18, 0x8c, 0x46, 0x22,
/* U+006E "n" */
0xb6, 0x63, 0x18, 0xc6, 0x20,
/* U+006F "o" */
0x7b, 0x38, 0x61, 0x87, 0x37, 0x80,
/* U+0070 "p" */
0xbb, 0x38, 0x61, 0x87, 0x3b, 0xa0, 0x80,
/* U+0071 "q" */
0x77, 0x38, 0x61, 0x87, 0x37, 0x41, 0x4,
/* U+0072 "r" */
0xba, 0x49, 0x20,
/* U+0073 "s" */
0x74, 0x60, 0xe0, 0xc7, 0xc0,
/* U+0074 "t" */
0x44, 0xf4, 0x44, 0x44, 0x30,
/* U+0075 "u" */
0x8c, 0x63, 0x18, 0xcd, 0xa0,
/* U+0076 "v" */
0x85, 0x14, 0x92, 0x28, 0xc1, 0x0,
/* U+0077 "w" */
0xc4, 0x53, 0x14, 0xc9, 0x2a, 0x32, 0x8c, 0xc3,
0x10,
/* U+0078 "x" */
0x45, 0x23, 0x4, 0x39, 0x2c, 0x40,
/* U+0079 "y" */
0x85, 0x14, 0x8a, 0x30, 0xc1, 0x8, 0x40,
/* U+007A "z" */
0xf8, 0xc4, 0x44, 0x63, 0xe0,
/* U+F001 "" */
0x0, 0x70, 0x3f, 0x1f, 0xf1, 0xfb, 0x1c, 0x31,
0x83, 0x18, 0x31, 0x83, 0x19, 0xf7, 0x9f, 0xf8,
0x47, 0x0,
/* U+F2ED "" */
0xe, 0x1f, 0xfc, 0x0, 0x0, 0x7, 0xfc, 0xd5,
0x9a, 0xb3, 0x56, 0x6a, 0xcd, 0x59, 0xab, 0x3f,
0xe0,
/* U+F304 "" */
0x0, 0x40, 0xe, 0x0, 0xf0, 0x37, 0x7, 0xa0,
0xfc, 0x1f, 0x83, 0xf0, 0x7e, 0xf, 0xc0, 0xf8,
0xf, 0x0, 0x80, 0x0,
/* U+F55A "" */
0xf, 0xfe, 0x3f, 0xfc, 0xfb, 0x3b, 0xf0, 0xff,
0xf3, 0xef, 0xc3, 0xcf, 0xb7, 0x8f, 0xff, 0xf,
0xfe,
/* U+F7C2 "" */
0x1f, 0x9a, 0xbe, 0xaf, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xf8,
/* U+F8A2 "" */
0x0, 0x0, 0x3, 0x30, 0x37, 0x3, 0xff, 0xff,
0xff, 0x70, 0x3, 0x0
* GLYPH DESCRIPTION
static const lv_font_fmt_txt_glyph_dsc_t glyph_dsc[] = {
{.bitmap_index = 0, .adv_w = 0, .box_w = 0, .box_h = 0, .ofs_x = 0, .ofs_y = 0} /* id = 0 reserved */,
{.bitmap_index = 0, .adv_w = 75, .box_w = 1, .box_h = 1, .ofs_x = 0, .ofs_y = 0},
{.bitmap_index = 1, .adv_w = 82, .box_w = 3, .box_h = 1, .ofs_x = 1, .ofs_y = 4},
{.bitmap_index = 2, .adv_w = 45, .box_w = 1, .box_h = 1, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 3, .adv_w = 115, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 11, .adv_w = 126, .box_w = 5, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 18, .adv_w = 116, .box_w = 5, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 25, .adv_w = 111, .box_w = 6, .box_h = 10, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 33, .adv_w = 118, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 41, .adv_w = 121, .box_w = 5, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 48, .adv_w = 117, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 56, .adv_w = 115, .box_w = 6, .box_h = 10, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 64, .adv_w = 115, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 72, .adv_w = 114, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 80, .adv_w = 141, .box_w = 9, .box_h = 10, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 92, .adv_w = 136, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 100, .adv_w = 134, .box_w = 7, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 109, .adv_w = 149, .box_w = 7, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 118, .adv_w = 120, .box_w = 5, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 125, .adv_w = 118, .box_w = 5, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 132, .adv_w = 137, .box_w = 7, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 141, .adv_w = 147, .box_w = 7, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 150, .adv_w = 50, .box_w = 1, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 152, .adv_w = 47, .box_w = 3, .box_h = 12, .ofs_x = 0, .ofs_y = -1},
{.bitmap_index = 157, .adv_w = 141, .box_w = 7, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 166, .adv_w = 118, .box_w = 5, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 173, .adv_w = 163, .box_w = 8, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 183, .adv_w = 143, .box_w = 7, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 192, .adv_w = 149, .box_w = 8, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 202, .adv_w = 133, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 210, .adv_w = 149, .box_w = 8, .box_h = 12, .ofs_x = 1, .ofs_y = -1},
{.bitmap_index = 222, .adv_w = 141, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 230, .adv_w = 120, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 238, .adv_w = 116, .box_w = 7, .box_h = 10, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 247, .adv_w = 140, .box_w = 7, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 256, .adv_w = 134, .box_w = 8, .box_h = 10, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 266, .adv_w = 213, .box_w = 13, .box_h = 10, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 283, .adv_w = 125, .box_w = 8, .box_h = 10, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 293, .adv_w = 123, .box_w = 7, .box_h = 10, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 302, .adv_w = 116, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 310, .adv_w = 110, .box_w = 6, .box_h = 7, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 316, .adv_w = 121, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 324, .adv_w = 100, .box_w = 5, .box_h = 7, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 329, .adv_w = 110, .box_w = 6, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 337, .adv_w = 105, .box_w = 6, .box_h = 7, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 343, .adv_w = 63, .box_w = 4, .box_h = 10, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 348, .adv_w = 110, .box_w = 6, .box_h = 9, .ofs_x = 1, .ofs_y = -1},
{.bitmap_index = 355, .adv_w = 113, .box_w = 5, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 362, .adv_w = 46, .box_w = 1, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 364, .adv_w = 43, .box_w = 3, .box_h = 12, .ofs_x = -1, .ofs_y = -1},
{.bitmap_index = 369, .adv_w = 116, .box_w = 5, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 376, .adv_w = 45, .box_w = 1, .box_h = 10, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 378, .adv_w = 168, .box_w = 9, .box_h = 7, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 386, .adv_w = 111, .box_w = 5, .box_h = 7, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 391, .adv_w = 110, .box_w = 6, .box_h = 7, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 397, .adv_w = 120, .box_w = 6, .box_h = 9, .ofs_x = 1, .ofs_y = -1},
{.bitmap_index = 404, .adv_w = 111, .box_w = 6, .box_h = 9, .ofs_x = 1, .ofs_y = -1},
{.bitmap_index = 411, .adv_w = 82, .box_w = 3, .box_h = 7, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 414, .adv_w = 95, .box_w = 5, .box_h = 7, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 419, .adv_w = 65, .box_w = 4, .box_h = 9, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 424, .adv_w = 110, .box_w = 5, .box_h = 7, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 429, .adv_w = 102, .box_w = 6, .box_h = 7, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 435, .adv_w = 167, .box_w = 10, .box_h = 7, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 444, .adv_w = 103, .box_w = 6, .box_h = 7, .ofs_x = 0, .ofs_y = 1},
{.bitmap_index = 450, .adv_w = 102, .box_w = 6, .box_h = 9, .ofs_x = 0, .ofs_y = -1},
{.bitmap_index = 457, .adv_w = 101, .box_w = 5, .box_h = 7, .ofs_x = 1, .ofs_y = 1},
{.bitmap_index = 462, .adv_w = 192, .box_w = 12, .box_h = 12, .ofs_x = 0, .ofs_y = -2},
{.bitmap_index = 480, .adv_w = 168, .box_w = 11, .box_h = 12, .ofs_x = 0, .ofs_y = -1},
{.bitmap_index = 497, .adv_w = 192, .box_w = 12, .box_h = 13, .ofs_x = 0, .ofs_y = -2},
{.bitmap_index = 517, .adv_w = 240, .box_w = 15, .box_h = 9, .ofs_x = 0, .ofs_y = 0},
{.bitmap_index = 534, .adv_w = 144, .box_w = 10, .box_h = 11, .ofs_x = 0, .ofs_y = -1},
{.bitmap_index = 548, .adv_w = 193, .box_w = 12, .box_h = 8, .ofs_x = 0, .ofs_y = 1}
* CHARACTER MAPPING
static const uint16_t unicode_list_0[] = {
0x0, 0xd, 0xe
static const uint16_t unicode_list_4[] = {
0x0, 0x2ec, 0x303, 0x559, 0x7c1, 0x8a1
/*Collect the unicode lists and glyph_id offsets*/
static const lv_font_fmt_txt_cmap_t cmaps[] =
.range_start = 32, .range_length = 15, .glyph_id_start = 1,
.unicode_list = unicode_list_0, .glyph_id_ofs_list = NULL, .list_length = 3, .type = LV_FONT_FMT_TXT_CMAP_SPARSE_TINY
.range_start = 48, .range_length = 10, .glyph_id_start = 4,
.unicode_list = NULL, .glyph_id_ofs_list = NULL, .list_length = 0, .type = LV_FONT_FMT_TXT_CMAP_FORMAT0_TINY
.range_start = 65, .range_length = 26, .glyph_id_start = 14,
.range_start = 97, .range_length = 26, .glyph_id_start = 40,
.range_start = 61441, .range_length = 2210, .glyph_id_start = 66,
.unicode_list = unicode_list_4, .glyph_id_ofs_list = NULL, .list_length = 6, .type = LV_FONT_FMT_TXT_CMAP_SPARSE_TINY
* ALL CUSTOM DATA
#if LVGL_VERSION_MAJOR == 8
/*Store all the custom data of the font*/
static lv_font_fmt_txt_glyph_cache_t cache;
#if LVGL_VERSION_MAJOR >= 8
static const lv_font_fmt_txt_dsc_t font_dsc = {
#else
static lv_font_fmt_txt_dsc_t font_dsc = {
.glyph_bitmap = glyph_bitmap,
.glyph_dsc = glyph_dsc,
.cmaps = cmaps,
.kern_dsc = NULL,
.kern_scale = 0,
.cmap_num = 5,
.bpp = 1,
.kern_classes = 0,
.bitmap_format = 0,
.cache = &cache
extern const lv_font_t lv_font_montserrat_12;
* PUBLIC FONT
/*Initialize a public general font descriptor*/
const lv_font_t myFont = {
#else
.get_glyph_dsc = lv_font_get_glyph_dsc_fmt_txt, /*Function pointer to get glyph's data*/
.get_glyph_bitmap = lv_font_get_bitmap_fmt_txt, /*Function pointer to get glyph's bitmap*/
.line_height = 13, /*The maximum line height required by the font*/
.base_line = 2, /*Baseline measured from the bottom of the line*/
#if !(LVGL_VERSION_MAJOR == 6 && LVGL_VERSION_MINOR == 0)
.subpx = LV_FONT_SUBPX_NONE,
#if LV_VERSION_CHECK(7, 4, 0) || LVGL_VERSION_MAJOR >= 8
.underline_position = -4,
.underline_thickness = 1,
.dsc = &font_dsc, /*The custom font data. Will be accessed by `get_glyph_bitmap/dsc` */
.fallback = &lv_font_montserrat_12,
.user_data = NULL,
#endif /*#if MYFONT*/
