I´m using ESP32 with Arduino IDE.
I´m using LVGL library and LVGL examples (form Library manager) versin 7.10.0
I would like to use ILI9341 LCD with HW SPI.
I can run it with SW SPI, but LCD is very slo.
#include <lvgl.h>
#include <lv_examples.h>
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#define _cs 5 // goes to TFT CS
#define _dc 21 // goes to TFT DC
#define _mosi 23 // goes to TFT MOSI
#define _sclk 18 // goes to TFT SCK/CLK
#define _rst -1 // goes to TFT RESET
#define _miso 19
// If using the breakout, change pins as desired
//Adafruit_ILI9341 tft = Adafruit_ILI9341(_cs, _dc, _mosi, _sclk, _rst, _miso); //SW works
Adafruit_ILI9341 tft = Adafruit_ILI9341(_cs, _dc, _rst); //HW does not work
#if USE_LV_LOG != 0
/* Serial debugging */
void my_print(lv_log_level_t level, const char * file, uint32_t line, const char * dsc)
Serial.printf("%s@%d->%s\r\n", file, line, dsc);
Serial.flush();
/* Display flushing */
uint32_t wh = w * h; //for Adafruit library
tft.startWrite();
while (wh--) tft.pushColor(color_p++->full); //for Adafruit library
tft.endWrite();
lv_disp_flush_ready(disp);
void setup()
#if USE_LV_LOG != 0
lv_log_register_print_cb(my_print); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation(1); /* Landscape orientation */
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 320;
disp_drv.ver_res = 240;
disp_drv.buffer = &disp_buf;
/* Try an example from the lv_examples repository
https://github.com/lvgl/lv_examples */
//lv_demo_widgets();
lv_demo_stress();
void loop()
delay(5);
When I upload code with call for HW SPI, I get just this at serial monitor and it´s look to me as that main loop is not working.
If I upload code with call for SW SPI, screen is working but framerate is very slow.
Have anyone idea what I could try to make it work with HW SPI?
Many thanks for help.
I know that this woudl work with it, but that is not goal of this. I want to make it work with library from Adafruit, as it is easy to setup and less confusing for begginers than TFT_eSPI.
