when I operate the lvgl demo it made some problem
ESP32 board and use the PlatformIo to programming
LVGL-V8.1
I wanna the animation can be used
I had made it to strong conversion, but it also reported problem
The following is the error report
Compiling .pio\build\esp32dev\src\main.cpp.o
src\main.cpp: In function 'void anim_x_cb(void*, int32_t)':
src\main.cpp:72:27: error: invalid conversion from 'void*' to '_lv_obj_t*' [-fpermissive]
lv_obj_set_x(var,v);
In file included from .pio\libdeps\esp32dev\lvgl/src/core/lv_obj.h:131:0,
from .pio\libdeps\esp32dev\lvgl/lvgl.h:35,
from src\Init.h:3,
from src\main.cpp:1:
.pio\libdeps\esp32dev\lvgl/src/core/lv_obj_pos.h:50:6: note: initializing argument 1 of 'void lv_obj_set_x(_lv_obj_t*, lv_coord_t)'
void lv_obj_set_x(struct _lv_obj_t * obj, lv_coord_t x);
Compiling .pio\build\esp32dev\lib756\lvgl\core\lv_obj_class.c.o
Compiling .pio\build\esp32dev\lib756\lvgl\core\lv_obj_draw.c.o
Compiling .pio\build\esp32dev\lib756\lvgl\core\lv_obj_pos.c.o
Compiling .pio\build\esp32dev\lib756\lvgl\core\lv_obj_scroll.c.o
Compiling .pio\build\esp32dev\lib756\lvgl\core\lv_obj_style.c.o
Compiling .pio\build\esp32dev\lib756\lvgl\core\lv_obj_style_gen.c.o
Compiling .pio\build\esp32dev\lib756\lvgl\core\lv_obj_tree.c.o
Compiling .pio\build\esp32dev\lib756\lvgl\core\lv_refr.c.o
Compiling .pio\build\esp32dev\lib756\lvgl\core\lv_theme.c.o
Compiling .pio\build\esp32dev\lib756\lvgl\draw\lv_draw_arc.c.o
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
Compiling .pio\build\esp32dev\lib756\lvgl\draw\lv_draw_blend.c.o
