lv_label_set_text_fmt(label_current_x,"%f",0.545);
Wrong display character f
There is a setting for this in lv_conf.h.
I canāt find it. Can you tell meļ¼
I donāt want to set font, I want to display floating point and the display character f
If you are not using a custom printf implementation:
If you are using a custom printf implementation, you will have to check its configuration.
Good thank you
Just an update for those using LVGL V9: Iāve run into this same issue, so hereās what fixes it now.
Set āLV_USE_FLOATā in the config to 1.
/* Use `float` as `lv_value_precise_t` */
#define LV_USE_FLOAT 1
I am using LVGL V9.1.0, however, setting
does not work for me. In the lv_conf.h file, Iāve also set
/* clang-format off */
When I use
lv_label_set_text_fmt(maxOD, "Max. OD: %f", maxODValue);
it still gives
Max. OD: f
as output. Any idea what I am missing?
