Ability Screen Shots
Is there a way to save what is currently on the screen to a png or the like? I am sure there is (As the data has to be somewhere right?)
This would be a really cool piece of functionality
Raspberry Pi ATM, VisualGDB Visual Studio 2019
7.7
A simple function to call to save a screen shot.
Not quite positive where to start, other than to start digging thru the core.
The trick that’s usually recommended is to divert the pixels from the display driver to a file.
  1. Set a flag e.g.: screenshot_mode = true
  2. Call lv_obj_invalidate(lv_scr_act());
  3. The driver will get the whole frame in several chunks according to LV_VDB_SIZE. Always full lines will be sent.
  4. If screenshot_mode == true save the parts one by one instead of sending them to the ILI9341
  5. When y2 == LV_VER_RES set screenshot_mode = false to go back to normal mode.
(source)
Very cool…
How difficult would it be to add something like:
save_screenshot(char *filename)
I think it would be easy, except that users’ requirements are different. Some would want a raw buffer to send over the air to another device. Others wouldn’t have enough RAM for that and would want it saved to a file.
Something like this might be better implemented as an example which can be copied into a project, rather than a core function.
Yeah, probs.
But I do like the idea of you doing my homework FOR me :slight_smile:
