I used the slider example, modifying its range and position.And I set the range from 0 to 20,000.When I drag the knob to the maximum, keep dragging, and it will go back to the minimum.
NXP MIMXRT1052
V7.7.1
When I drag the knob to the maximum, keep dragging,its value stays the same.
When I used version 7.11.0, it had the same problem.
video.zip (1.6 MB)
static void slider_event_cb(lv_obj_t * slider, lv_event_t event);
static lv_obj_t * slider_label;
void lv_ex_slider_2(void)
/* Create a slider in the center of the display */
lv_obj_t * slider = lv_slider_create(lv_scr_act(), NULL);
lv_obj_set_width(slider, LV_DPI * 2);
lv_obj_align(slider, NULL, LV_ALIGN_CENTER, -200, 0);
lv_obj_set_event_cb(slider, slider_event_cb);
lv_slider_set_range(slider, 0, 20000);
/* Create a label below the slider */
slider_label = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(slider_label, "0");
lv_obj_set_auto_realign(slider_label, true);
lv_obj_align(slider_label, slider, LV_ALIGN_OUT_BOTTOM_MID, 0, 10);
/* Create an informative label */
lv_obj_t * info = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(info, "Welcome to the slider+label demo!\n"
"Move the slider and see that the label\n"
"updates to match it.");
lv_obj_align(info, NULL, LV_ALIGN_IN_TOP_LEFT, 10, 10);
if(event == LV_EVENT_VALUE_CHANGED) {
static char buf[6]; /* max 3 bytes for number plus 1 null terminating byte */
snprintf(buf, 6, "%u", lv_slider_get_value(slider));
lv_label_set_text(slider_label, buf);
## Screenshot and/or video
The video is in the zip file.
[video.zip|attachment](upload://4eXXPusZuEYca70yq5D2yptUqiM.zip) (1.6 MB)
