Hi, if possible, could you help me? This issue is taking up a lot of my time. I want to rotate my display by 90 degrees, essentially setting it to portrait mode. I’ve used the information from the site below, but it only cropped half of the screen. Here’s the code for my project—what line of code should I add to make my display switch to portrait mode?
lvgl - esp32-8048S043
#include <lvgl.h>
#define TFT_BL 2
#define GFX_BL DF_GFX_BL
#if defined(DISPLAY_DEV_KIT)
Arduino_GFX *gfx = create_default_Arduino_GFX();
#else
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
GFX_NOT_DEFINED, GFX_NOT_DEFINED, GFX_NOT_DEFINED,
40, 41, 39, 42,
45, 48, 47, 21, 14,
5, 6, 7, 15, 16, 4,
8, 3, 46, 9, 1
Arduino_RPi_DPI_RGBPanel *gfx = new Arduino_RPi_DPI_RGBPanel(
bus,
800, 0, 8, 4, 8,
480, 0, 8, 4, 8,
1, 14000000, true);
#include "touch.h"
static uint32_t screenWidth;
static uint32_t screenHeight;
static lv_color_t *disp_draw_buf;
#if (LV_COLOR_16_SWAP != 0)
gfx->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#else
gfx->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
lv_disp_flush_ready(disp);
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
if (touch_has_signal())
if (touch_touched())
data->point.x = touch_last_x;
data->point.y = touch_last_y;
else if (touch_released())
void lv_example_get_started_2(void)
lv_obj_t * btn = lv_btn_create(lv_scr_act());
lv_obj_set_pos(btn, screenWidth / 2 - 60, screenHeight / 2 - 25);
lv_obj_set_size(btn, 120, 50);
lv_obj_add_event_cb(btn, btn_event_cb, LV_EVENT_ALL, NULL);
lv_obj_t * label = lv_label_create(btn);
lv_obj_center(label);
static void btn_event_cb(lv_event_t * e)
lv_obj_t * btn = lv_event_get_target(e);
static uint8_t cnt = 0;
cnt++;
lv_obj_t * label = lv_obj_get_child(btn, 0);
lv_label_set_text_fmt(label, "Button: %d", cnt);
void setup()
Serial.begin(115200);
Serial.println("LVGL Widgets Demo");
touch_init();
gfx->begin();
#ifdef TFT_BL
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
gfx->fillScreen(RED);
delay(500);
gfx->fillScreen(GREEN);
delay(500);
gfx->fillScreen(BLUE);
delay(500);
gfx->fillScreen(BLACK);
delay(500);
delay(10);
screenWidth = gfx->width();
screenHeight = gfx->height();
#ifdef ESP32
disp_draw_buf = (lv_color_t *)heap_caps_malloc(sizeof(lv_color_t) * screenWidth * screenHeight/4 , MALLOC_CAP_INTERNAL | MALLOC_CAP_8BIT);
#else
disp_draw_buf = (lv_color_t *)malloc(sizeof(lv_color_t) * screenWidth * screenHeight/4);
if (!disp_draw_buf)
Serial.println("LVGL disp_draw_buf allocate failed!");
lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight/4);
lv_disp_drv_init(&disp_drv);
lv_example_get_started_2();
Serial.println("Setup done");
void loop()
lv_timer_handler();
delay(5);
