4" TFT display using a ST7796s driver produces a white stripe which offsets actual screen content. I should note that I am a noob when it comes to C. I can do some stuff on my own but nothing complex.
LVGL actually runs, but I’ve hidden most widgets so only the background color is displayed. When aligning widgets to a specific corner of the screen, they actually rotate when I change the screen orientation, which is to be expected. However I can’t explain the white “uninitialized” (?) part. I don’t even know how to search correctly for this issue. Its place on the screen is also dependent on which orientation I choose, but is always visible.
I seem to have a similar issue to this thread, but I have a different setup. What else could I change to make this work? It seems to be anThis text will be hidden issue with the driver, but I can’t tell for sure.
ESP32-S3 DevKit-C, IDF 5.1.1
The x = 0, y = 0 screen origin is not in the correct spot
Messing around in the driver (screen was mirrored in the x axis, but is now fixed)
Selecting ILI9488 as the driver (I’ve read that it was similar to mine, did not work)
Swapping horizontal and vertical resolution
Changing orientation
Link to the video:
