I have a ili9341 16-bit color display, how can I display a transparent color on it?
ESP32
I want to achieve a picture with a transparent color
I turned the image into a True color chroma key C array, which is a disordered line on the display, and it doesn’t display properly.
“Doesn’t display properly” is not enough information for us to diagnose the issue. A screenshot would be helpful. Does it work with regular True color mode or True color with alpha mode?
I converted the image to a true color chroma keyed format and imported it into the project. The code is as follows:
LV_IMG_DECLARE(test)
void create(){
lv_obj_t *test_image = lv_img_create(lv_disp_get_scr_act(NULL), NULL);
lv_img_set_src(test_image, &test);
test.c (866.4 KB)
device photo:
It seems that there are only white lines, and only part of it
my lv_conf.h is like this
#define LV_COLOR_DEPTH 32
#define LV_COLOR_16_SWAP 0
#define LV_COLOR_SCREEN_TRANSP 1
#define LV_COLOR_TRANSP LV_COLOR_LIME
#define LV_ANTIALIAS 1
#define LV_DISP_DEF_REFR_PERIOD 30 /*[ms]*/
#define LV_DPI 100 /*[px]*/
typedef int16_t lv_coord_t;
Memory manager settings
#define LV_MEM_CUSTOM 1
#if LV_MEM_CUSTOM == 0
# define LV_MEM_SIZE (32U * 1024U)
# define LV_MEM_ATTR
# define LV_MEM_ADR 0
# define LV_MEM_AUTO_DEFRAG 1
#else /*LV_MEM_CUSTOM*/
# define LV_MEM_CUSTOM_INCLUDE <stdlib.h> /*Header for the dynamic memory function*/
# define LV_MEM_CUSTOM_ALLOC malloc /*Wrapper to malloc*/
# define LV_MEM_CUSTOM_FREE free /*Wrapper to free*/
#endif /*LV_MEM_CUSTOM*/
Why did you set LV_COLOR_DEPTH 32
if you have a 16 bit display?
Does the other drawings work well? Buttons, labels, etc.
Next time please format your code like this:
your
code
here
Is it possible to display a transparent PNG image on a 16-bit color depth display? I put an image button on the background image, I want it to appear to be partially transparent.
You should be able to display transparent images on any color depth within LittlevGL, but you can’t draw a background with another library and then have LittlevGL transparently draw on top of it (unless you are using 32-bit color depth and you’ve enabled the appropriate setting in lv_conf.h
I understand what you mean, I made a new attempt, but it still shows up abnormally.
This is my configuration:
#define LV_COLOR_DEPTH 16
#define LV_COLOR_16_SWAP 1
#define LV_COLOR_SCREEN_TRANSP 0
This is my original picture:
On this page(
https://littlevgl.com/image-to-c-array ), I chose true color chroma keyed
When I select true color instead of true color chroma keyed, it displays correctly
