recently try build micropython 1.20 version
- more warning error
- missing partition
any solved error ?
decompress the attached zip file into the ports/esp32 folder. You will be prompted to overwrite so you will have to say yes.
partitions.zip (333 Bytes)
Then run the build again , make sure you do a clean and then build.
They are warnings, just ignore them
thank you
last one doubt , how downgrade lvgl version 8.3.6 because we are using squareline studio lvgl version 8.3.6
but not available lv_blinding micropython ??
how change ??
