Hi guys,
I am trying to transplant LVGL to STM32H750Disco. I have made my LCD and touch pad working. It can display the button with the button example code listed below. But the button widget doesn’t respond to my click, it doesn’t change at all. I can only see the output “Clicked” and “Toggled” from the serial port, which shows my touch pad driver works fine. Is there anything I did wrong? Thanks.
STM32H750Disco
V7.10
printf("Clicked\n");
else if(event == LV_EVENT_VALUE_CHANGED) {
printf("Toggled\n");
void lv_ex_btn_1(void)
lv_obj_t * label;
lv_obj_t * btn1 = lv_btn_create(lv_scr_act(), NULL);
lv_obj_set_event_cb(btn1, event_handler);
lv_obj_align(btn1, NULL, LV_ALIGN_CENTER, 0, -40);
label = lv_label_create(btn1, NULL);
lv_obj_t * btn2 = lv_btn_create(lv_scr_act(), NULL);
lv_obj_set_event_cb(btn2, event_handler);
lv_obj_align(btn2, NULL, LV_ALIGN_CENTER, 0, 40);
lv_btn_set_checkable(btn2, true);
lv_btn_toggle(btn2);
lv_btn_set_fit2(btn2, LV_FIT_NONE, LV_FIT_TIGHT);
label = lv_label_create(btn2, NULL);
lv_label_set_text(label, "Toggled");
