When an event is triggered by touching a switch, LV_EVENT_CLICKED
and LV_EVENT_PRESSED
events occur only once, while LV_EVENT_VALUE_CHANGED
occurs twice.
Is this normal?
static void event_handler_x(lv_event_t * e)
if(code == LV_EVENT_VALUE_CHANGED) {
// repeat twice
LV_LOG_USER("State: %s\n", lv_obj_has_state(obj, LV_STATE_CHECKED) ? "On" : "Off");
else if(code == LV_EVENT_CLICKED) {
// only once
else if(code == LV_EVENT_PRESSED) {
// only once
void example(void)
lv_obj_set_flex_flow(lv_scr_act(), LV_FLEX_FLOW_COLUMN);
lv_obj_set_flex_align(lv_scr_act(), LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER);
lv_obj_t * sw;
sw = lv_switch_create(lv_scr_act());
lv_obj_add_event_cb(sw, event_handler_x, LV_EVENT_CLICKED, NULL);
lv_obj_add_event_cb(sw, event_handler_x, LV_EVENT_PRESSED, NULL);
lv_obj_add_event_cb(sw, event_handler_x, LV_EVENT_VALUE_CHANGED, NULL);
