in lv_obj.c
there’s a comment that these aren’t copied from copy
to parent
, but whats the justification for this? If I make a custom lv_btn
with a different signal handler, I’d expect that my copy would have the same signal handler.
The comment says
/*Only copy the `event_cb`. `signal_cb` and `design_cb` will be copied in the derived
* object type (e.g. `lv_btn`)*/
Let’s say you copy an lv_page
First an lv_obj
is create. If it’d copy the signal function and lv_obj_create
calls e.g. lv_obj_set_size
LV_SIGNAL_COORDS_CHG
would be sent to the lv_page_signal
. But at this point we are still far from having an lv_page
because still only lv_obj
is being created.
Therefore the create
functions set their own signal/design
functions when they created everything needed.
Here you can see how/where lv_page_create
sets the signal functions. So the copy will have the correct signal function:
