Because of nrf spi speed limitation for LCD , when try to create object, e.g: LV_LIST, and add some different state styles, and scroll up/down, the button items move very slow, and it seems every states/styles trans of a widget has anim effect by default, So need to know how and where to remove all style transition/anim effects of widget, and it’s better it can be done when object/widget created
nrf52840 with segger embedded studio
8,3
A way to disable “all” style/event animi/transition of widgets when object created , because I dont know how to, how many and where to do so, hope performance will be same as lvgl7.
1.Refer to How to disable the scroll animations of TableView - #4 by lagadmar, set anim time to 0, but still slow, maybe need to find out more event has anim effect.
2.Try to step debugging to see which style,callback anim/transition effect will be called. eg: background, then try to add zero timing transition for some style of state, no obvious improve
- Where to disable: modify following related settings,result is better
lv_object_scroll.c,
#define SCROLL_ANIM_TIME_MIN 0//200 /ms/
#define SCROLL_ANIM_TIME_MAX 0//400 /ms/
disable LV_USE_ANIMIMG
LV_THEME_DEFAULT_TRANSITION_TIME = 0
static void btn_event_handlers(lv_event_t *e) {
lv_anim_t * a = (lv_anim_t *) lv_event_get_param(e);
switch(code){
case LV_EVENT_PRESSED:
if (a) a->time = 0;
break;
case LV_EVENT_CLICKED:
if (a) a->time = 0;
break;
case LV_EVENT_LONG_PRESSED:
if (a) a->time = 0;
break;
case LV_EVENT_LONG_PRESSED_REPEAT:
if (a) a->time = 0;
break;
case LV_EVENT_KEY:
if (a) a->time = 0;
break;
case LV_EVENT_FOCUSED:
if (a) a->time = 0;
break;
default:
break;
main()
lv_style_reset(&style_watchface_list_btn);
lv_style_reset(&style_watchface_list_btn_pressed);
lv_style_reset(&style_watchface_list_btn_focused);
lv_style_set_bg_color(&style_watchface_list_btn, lv_color_make(0x00, 0x00, 0x00));
lv_style_set_bg_color(&style_watchface_list_btn_pressed, lv_color_make(0x00, 0x00, 0xFF));
lv_style_set_bg_color(&style_watchface_list_btn_focused, lv_color_make(0x00, 0x00, 0x00));
static const lv_style_prop_t props[] = {LV_STYLE_PROP_ANY, 0};
static lv_style_transition_dsc_t trans_pr;
lv_style_transition_dsc_init(&trans_pr, props, lv_anim_path_linear, 0, 0, NULL);
lv_style_set_transition(&style_watchface_list_btn, &trans_pr);
lv_style_set_transition(&style_watchface_list_btn_pressed, &trans_pr);
lv_style_set_transition(&style_watchface_list_btn_focused, &trans_pr);
lv_style_set_anim_time(&style_watchface_list_btn,0);
lv_style_set_anim_time(&style_watchface_list_btn_pressed,0);
lv_style_set_anim_time(&style_watchface_list_btn_focused,0);
watchface_list = lv_list_create(page);
for (int i = 0; i < 7; i++) {
uint8_t x = 0;
list_btns[i] = lv_btn_create(watchface_list);
lv_obj_set_size(list_btns[i], 360, 80);
lv_obj_add_style(list_btns[i], &style_watchface_list_btn,LV_STATE_DEFAULT);
lv_obj_add_style(list_btns[i], &style_watchface_list_btn_focused,LV_STATE_FOCUSED);
lv_obj_add_style(list_btns[i], &style_watchface_list_btn_pressed,LV_STATE_PRESSED);
lv_obj_add_event_cb(list_btns[i], btn_event_handlers, LV_EVENT_ALL , NULL);
