when i use it in LittlevGL/MicroPython simulator for test to design ui, .i hope to get a list in python,but it just return <class ‘BJOB’>. And i can’t find this class on mircopython.
self.btnm_map = ["0","0","0","0","0","0","0","0",""]
print(self.btnm_map)
self.button_matrix = lv.btnm(page)
self.button_matrix.set_size(240,30)
self.button_matrix.set_map(self.btnm_map)
map_array = self.button_matrix.get_map_array()
print(type(map_array))
Button’s text
There is a text on each button. To specify them a descriptor string array, called map , needs to be used. The map can be set with lv_btnmatrix_set_map(btnm, my_map)
. The declaration of a map should look like const char * map[] = {"btn1", "btn2", "btn3", ""}
. Note that the last element has to be an empty string !
In Usage, the author assume the map array is end of ‘\0’,this is why i think we can implemts the method of class btnm.get_map_array.
