Ohhh, all these are amazing! It seems we really have a lot to talk about! ![]()
Could you write an email to gabor@lvgl.io to discuss what we can do together? ![]()
you like that huh? The real kick is that it is being done using MicroPython and is written in Python code which is some 200 times slower than C code. The example above is running with MicroPython compiled for Linux. If it was running on an MCU the performance would be a whole lot slower than what is being seen here but I would expect it to be about the same as what you are seeing here is the code was written in Cβ¦
@FishOfTheNorthStar cleaned up the texture mapping so the quality is a lot better and we both worked on doing some code optimization to get better performance from it. The example is before the code was changed to clean up the output.
