I developed an application by using LVGL, the application includes the function to connect the API server by websocket, the application calls the APIs provided by the libcurl library, all functions works well in simulator when compiling from C code.
When I converted the C code to a single html file by using lv_web_emscripten tool, the API server can’t be connected, “websocket connect failed” message is got。
Any comments or suggestion would be appreciated.
Simulator
LVGL v8.3.10
The generated HTML file can works well to connect to the JSON-RPC server.
No idea about the root cause of the issue.
The following code is used to connect to the API server, the functions prefixed by curl_easy_ are provided by libcurl library. When converting to html file by lv_web_emscripten, the websocket doesn’t work anymore.
/* init and connect the websocket instance*/
CURL * websocket_connect(const char *ws_url)
CURL ws_curl;
CURLcode res;
#ifdef DEBUG
fprintf(stdout, “\nInit curl connection to %s\n”, ws_url);
ws_curl = curl_easy_init();
if (ws_curl == NULL)
fprintf(stderr, “ERROR: Failed to start a curl session.\n”);
message_display(“ERROR: Failed to start a curl session.\n”);
return NULL;
/set the ws link address`/
curl_easy_setopt(ws_curl, CURLOPT_URL, ws_url);
/set the websocket option: stop when connected to target server/
curl_easy_setopt(ws_curl, CURLOPT_CONNECT_ONLY, 2L);
/ Perform the request, res will get the return code */
res = curl_easy_perform(ws_curl);
if (res != CURLE_OK)
websocket_error(res, NULL);
curl_easy_cleanup(ws_curl);
return NULL;
return ws_curl;
NA
