Pc simulator, visual studio
What do you experience?
The LV_EVENT_VALUE_CHANGED is not happing on dropdown list when the driver is in encoder.
This was working perfect in V6 but now with V7 something goes wrong.
for the moment I modified the simulator a bit so I can use an encoder. So I started from the basic lv_ex_dropdow_1
static lv_indev_t * encoder_indev;
static lv_group_t* pxGroup;
static void event_handler(lv_obj_t* obj, lv_event_t event)
if (event == LV_EVENT_VALUE_CHANGED) {
char buf[32];
lv_dropdown_get_selected_str(obj, buf, sizeof(buf));
printf("Option: %s\n", buf);
void lv_ex_dropdown_custom(void)
/*Create a normal drop down list*/
lv_obj_t* ddlist = lv_dropdown_create(lv_scr_act(), NULL);
lv_dropdown_set_options(ddlist, "Apple\n"
"Banana\n"
"Orange\n"
"Melon\n"
"Grape\n"
"Raspberry");
lv_obj_align(ddlist, NULL, LV_ALIGN_IN_TOP_MID, 0, 20);
lv_obj_set_event_cb(ddlist, event_handler);
pxGroup = lv_group_create();
lv_indev_set_group(encoder_indev, pxGroup);
lv_group_add_obj(pxGroup, ddlist);
lv_group_focus_obj(ddlist);
I made this read encoder function, to use the arrows and enter buttons on the keyboard:
static bool prvReadEncoder(lv_indev_drv_t* indev_drv, lv_indev_data_t* data)
lv_indev_data_t xKeyboardData;
bool returnValue = keyboard_read(NULL, &xKeyboardData);
if (returnValue)
/* check if the button was pressed */
if (xKeyboardData.key == LV_KEY_ENTER)
else if (xKeyboardData.key == LV_KEY_LEFT)
data->enc_diff--;
else if (xKeyboardData.key == LV_KEY_RIGHT)
data->enc_diff++;
data->enc_diff = 0;
return returnValue;
made a small change to the keyboard read function:
bool keyboard_read(lv_indev_drv_t * indev_drv, lv_indev_data_t * data)
(void) indev_drv; /*Unused*/
data->state = state;
data->key = keycode_to_ascii(last_key);
state = LV_INDEV_STATE_REL;
return data->state == LV_INDEV_STATE_PR ? true : false;
//return false;
and I register the encoder like this:
lv_indev_drv_t encoder_drv;
lv_indev_drv_init(&encoder_drv);
encoder_drv.type = LV_INDEV_TYPE_ENCODER;
encoder_drv.read_cb = prvReadEncoder;
encoder_indev= lv_indev_drv_register(&encoder_drv);
