Hi @pete-pjb @kisvegabor, this is my test:
Target:
- disp: 800X480
- ram: <120K
- psram: 8M
lvgl version:
8.3.3
Question:
In demo 1, may be the implementation B is the best, but in demo 2, it’s the worst. so I need know which implementation is best on my device?
note:
Implementation B: It is implemented according to @pete-pjb code
Implementation C: in flush_cb, copy data to 800X480X2 psram.
I suggest “C”. It uses the least RAM and results in the best performance in demo 1 and almost as good as the best in demo 2.
Hi @kisvegabor
I’m facing same issue that LVGL fps is too low in my device.
I have tried separating the draw buffer into 1/8 of the displaybuffer.
My panel’s resolution is 1280*720, and I only have a 256K ram can be used. So I set the draw buffer to 1/8 as 38400.
But in the draw_bg() in lv_draw_sw_rect.c
the function continued to draw the buffer over the draw buffer size so it will cause memory overwrite.
As you can see in the Image, the function draw the buffer over 720/8=90 in vertical.
I wonder how to resolve it? Below is the related code
Thanks for your help.
AT_NONCACHEABLE_SECTION_ALIGN(uint8_t s_displayFrameBuffer[1][APP_PANEL_HEIGHT * APP_PANEL_WIDTH * APP_BPP ],
APP_PANEL_FB_ADDR_ALIGN_BYTE);
AT_NONCACHEABLE_SECTION_ALIGN(uint8_t draw_buf[APP_PANEL_HEIGHT * APP_PANEL_WIDTH * 2 / 8],
static void littlevgl_flush_callback(lv_disp_drv_t *disp_drv, const lv_area_t *area, lv_color_t *color_p)
#if 1
uint32_t bufferAddr = 0;
uint32_t w = lv_area_get_width(area);
uint32_t y;
while (APP_IsContentStreamShadowPending())
copy_area(area, color_p, (uint8_t*)s_displayFrameBuffer, APP_PANEL_WIDTH * 2);
APP_TriggerContentStreamShadowLoad();
#else
xSemaphoreGive(lvglSemaphore);
void lv_port_disp_init(void)
memset(s_displayFrameBuffer, 0, ARRAY_SIZE(s_displayFrameBuffer));
lv_disp_draw_buf_init(&disp_buf, draw_buf, NULL , APP_PANEL_FB_STRIDE_PIXEL * APP_FB_HEIGHT* APP_BPP/8);
/*Descriptor of a display driver*/
disp_drv.hor_res = APP_FB_WIDTH;
disp_drv.ver_res = APP_FB_HEIGHT;
disp_drv.flush_cb = littlevgl_flush_callback;
/*Set a display buffer*/
Regards,
Joseph
