Upgrading from v6 to v7, trouble with styling base objects
My v6 GUI is mostly built of base objects (boxes) that are styled and arranged. Moving to v7, using styles, none of the base objects are taking the style properties. They are all white with black text.
Is there some secret to styling base objects in v7?
IMXRT1062, arm-gcc
release/v7
Styling of base objects
Creating a style and applying it to the base object. Migrating v6 code. Using docs from: https://docs.lvgl.io/latest/en/html/widgets/obj.html#style
	static lv_style_t lv_style_plain;
	lv_style_copy(&style_box_no_border, &lv_style_plain);
	lv_style_set_bg_color(&style_box_no_border, LV_STATE_DEFAULT, LV_COLOR_BLACK);
	lv_style_set_bg_grad_color(&style_box_no_border, LV_STATE_DEFAULT, LV_COLOR_BLACK);
	lv_style_set_bg_opa(&style_box_no_border, LV_STATE_DEFAULT, LV_OPA_COVER);
	lv_style_set_pad_top(&style_box_no_border, LV_STATE_DEFAULT, 0);
	lv_style_set_pad_bottom(&style_box_no_border, LV_STATE_DEFAULT, 0);
	lv_style_set_pad_left(&style_box_no_border, LV_STATE_DEFAULT, 0);
	lv_style_set_pad_right(&style_box_no_border, LV_STATE_DEFAULT, 0);
	lv_style_set_pad_inner(&style_box_no_border, LV_STATE_DEFAULT, 0);
	lv_style_set_border_width(&style_box_no_border, LV_STATE_DEFAULT, 0);
	lv_obj_t *controller_bar;
	controller_bar = lv_obj_create(parent, NULL);
	lv_obj_set_size(controller_bar, 320, 18);
	lv_obj_align(controller_bar, NULL, LV_ALIGN_IN_TOP_MID, 0, -1);
	lv_obj_add_style(controller_bar, LV_OBJ_PART_MAIN, &style_box_no_border);
N/A
I assume that lv_style_plain has been initialized elsewhere, but I don’t see you calling lv_style_init on &style_box_no_border.
Thanks, I think that was it. The example in the docs doesn’t show the style_init, so it wasn’t clear, but makes sense now. https://docs.lvgl.io/latest/en/html/overview/style.html#initialize-styles-and-set-get-properties
Also, if the style is copied it shouldn’t be initialized, just to be clear.
