Hi, I see that the LVGL framebuffer port hasn’t been updated in a a while, and is still on the preliminary version of v7.0.0, is there a way to get the library up to date (v7.11)?
Thank you
Thank you
git pull && git checkout release/v7
in all three submodule directories should do the trick.
ah ok, thank you
will update and get back
@embeddedt I seem to have a problem with the touch screen not being able to detect my input, I have used evtest and mapped the correct /dev/input/event3
path, and checked for code snippets in the forum regd. this part, my log says this everytime:
lv_indev_drv_register: no display registered hence can't attache the indev to a display
I’m also just tinkering with the standard demo, to make sure I can first get everything working and also add this code after fbdev_init();
lv_indev_drv_t indev_drv;
indev_drv.read_cb = evdev_read;
I’ve fixed that, and now touch seems to work
only problem is that touch is working fine but the screen resolution isn’t working just right on the github verison of lv_port_linux_frame_buffer
once I pull the latest code, and apply the respective changes from my old one, the screen works, but the touch is completely wonky
I have atttached these two videos for reference, it shows the before and after:
before:
after:
